5.9 Dakota-chirp, chirp, chirp..................... #834829
10/20/10 08:09 PM
10/20/10 08:09 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
My Dakota is making a chirping noise on deceleration and at idle. It pretty much only does it when the throttle blades are closed. Noise seems to be coming from the area of the A/C compressor. Only does it after the truck is good and warmed up. It will make a whistle when the key is shut off, and will sometimes whislte after the motor has quit turning. I am inclined to think vacuum, but I have checked every hose, and gone all around the throttle body with WD-40 and can't find a leak.
Any clues?
Thanks!
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: slantzilla] #834830
10/20/10 09:18 PM
10/20/10 09:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I put a cheap belt on my durango and it started doing that, though it must be a pulley and replaced the one it sounded like it was comeing from, no luck, replaced the tensioner no luck, swapped altenator with my dakota, no luck put on a "premium" belt and no noise.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: HotRodDave] #834831
10/20/10 11:12 PM
10/20/10 11:12 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
I have a 88 dodge van that made the same noises,I ended up taking all of the belts off and went for a ride...still made chirping sounds whenever it felt like it. Turned out to be the clutch fan.Once I replaced that,I've never heard the sound again.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: 2DoorPost] #834832
10/21/10 06:55 PM
10/21/10 06:55 PM
Park Forest, IL
Park Forest, IL
I put a good belt on it about a year ago. I've thought about the fan clutch too, but I have watched as the motor is shut off and heard the noise after the engine and fan quit turning.
I'm going to take it down to my shop Saturday and pull the shroud for a closer look-see.
Thanks!
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: slantzilla] #834833
10/21/10 10:19 PM
10/21/10 10:19 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Remove the oil fill cap and see if it goes away.
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: Curt] #834834
10/21/10 11:36 PM
10/21/10 11:36 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Check the blt tensioner too. If it is seizing up the belt can chirp.
With it running CAREFULLY reach in with a 15 MM wrench and pull it a little tighter, and if the noise goes away it is the tensioner.
you have to do it with it running because the starting torque moves the tensioner.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: fox] #834835
10/22/10 12:31 AM
10/22/10 12:31 AM
hooziewhatsit Offline
spray a little water on the belts. It should quiet them down if that's what it is.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: slantzilla] #834836
10/22/10 07:24 PM
10/22/10 07:24 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Thanks!
Interesting...
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: Curt] #834837
10/22/10 07:51 PM
10/22/10 07:51 PM
Park Forest, IL
Park Forest, IL
Thanks!
Interesting...
Yes it is. That's why at this time I am 99% certain it is not the belts. The oil cap idea is intriguing though. Motor does have about 170K on it and could be getting loose inside, even thought it burns very little oil.
I am taking off in the morning to go to my shop. By the time I come home tomorrow night I will have either an answer or a new truck.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: slantzilla] #834838
10/22/10 09:26 PM
10/22/10 09:26 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Pull the dipstick instead, it will be less mess. See if it was excessive crankcase vacuum.
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: wheelsup68dart] #834839
10/23/10 05:32 PM
10/23/10 05:32 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Yeah that is what I am thinking...either way vent the crankcase.
Curt
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: Curt] #834840
10/23/10 07:00 PM
10/23/10 07:00 PM
Park Forest, IL
Park Forest, IL
And the winner is..............................
Curt with an honorable mention to Lonnie.
Got to thinking about this on the way to the shop. I remembered that I changed the breather hose from the valve cover to the intake on my K&N a couple months ago. I wasn't real fond of the way the hose routed under the bracket but forgot about it. The hose was kinked and had fused itself shut. Pulled the fitting/grommet out of the valve cover and a huge "WHOOSH" greeted me.
I rerouted the hose and made sure it can't kink, no more chirp.
Thanks all!
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: slantzilla] #834841
10/24/10 10:20 PM
10/24/10 10:20 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Sorry to put the kaibosh on the new truck... Maybe it will throw a rod and make the decision easier.....just kidding.
Curt
Re: 5.9 Dakota-chirp, chirp, chirp..................... [Re: Curt] #834842
10/25/10 09:35 PM
10/25/10 09:35 PM
Park Forest, IL
Park Forest, IL
Not at all. I am hoping to get another couple years out of this truck. It's still in fairly good shape for the miles, and the 5.9 has gobs of power to pull my trailer.
Wife has already given me the go ahead on a new truck though.
