Hoisting an Engine/Transmission? #834648
10/20/10 01:21 PM
10/20/10 01:21 PM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
Just wondering if I need any grade bolts or if I should use the water pump and intake manifold bolts? It's a 400 Chrysler and 727 setup. My Harbor Freight Engine Hoist is setup for two tons. I am wondering if I should get another chain other than what comes with the hoist? Also, if I need any other bolts what size and how long should I get and where should I attach? Thanks in advance.
Re: Hoisting an Engine/Transmission? [Re: OrangeProwler] #834649
10/20/10 01:50 PM
10/20/10 01:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Go get this and be done with it!!
http://www.harborfreight.com/3-4-ton-capacity-heavy-duty-load-leveler.html
It bolts to the intake bolts on or off but better off.
I got mine up hear years ago form princes auto (Canadian version of harbor freight)
and I could not be happier .
Tilt motor up and out then level again!!
see below
http://s542.photobucket.com/albums/gg408/dodgeboy8/?action=view&current=almost.jpg
Re: Hoisting an Engine/Transmission? [Re: Dodgem] #834650
10/20/10 02:02 PM
10/20/10 02:02 PM
Middle of A Field
O
O
Middle of A Field
Thanks Dodgem I actually just ordered this one to use. http://www.summitracing.com/parts/SUM-G1021/
Re: Hoisting an Engine/Transmission? [Re: OrangeProwler] #834651
10/20/10 02:07 PM
10/20/10 02:07 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I use grade-8 bolts on all lifting points, and for attaching it to the engine stand. They may not be necessary, but they're not that expensive and I figure it's cheap insurance.
Re: Hoisting an Engine/Transmission? [Re: Fab64] #834652
10/21/10 01:55 PM
10/21/10 01:55 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
on the leveler, it was the best money I ever spent. I bought one from Harbor Freight, it needed some "tweaking," but now it works as well as my buddy's expensive one. The main assembly is fine, the Chinese skimp on the hardware and chains so I fixed it. It makes putting them in MUCH easier.
Re: Hoisting an Engine/Transmission? [Re: 4BBodies] #834653
10/21/10 02:15 PM
10/21/10 02:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I like this one.
http://myks-tools.com/
Re: Hoisting an Engine/Transmission? [Re: Neil] #834654
10/22/10 12:53 PM
10/22/10 12:53 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I know a lot of people use those carb lifting plates, but I'd have a hard time trusting those four little 3/8 bolts to hold a big block and transmission. Especially in an aluminum intake.
I'd really be thinking about it when the engine is sky-hig and dangling over my car!
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Hoisting an Engine/Transmission? [Re: HitIt] #834655
10/22/10 12:58 PM
10/22/10 12:58 PM
Middle of A Field
O
O
Middle of A Field
Thanks guys. What we did is have a chain running from the bolts on the transmission bellhouse and the front intake manifold.
Re: Hoisting an Engine/Transmission? [Re: Neil] #834656
10/22/10 03:19 PM
10/22/10 03:19 PM
AndyF Offline
AndyF  Offline
Yep, the Myks one works great. Only one I use anymore.
Re: Hoisting an Engine/Transmission? [Re: HitIt] #834657
10/22/10 06:03 PM
10/22/10 06:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's to bad, because the carb lifting plate is much more compact and easier to use than those load levers.
I have used a home made carb lifting plate for 30 years now, I have lifted countless motors with one, even heavy International gas truck engines which weigh way more than a BB.
Re: Hoisting an Engine/Transmission? [Re: Challenger 1] #834658
10/22/10 07:23 PM
10/22/10 07:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
And the 4 bolts are 5/16, and still do the job.
Re: Hoisting an Engine/Transmission? [Re: AndyF] #834659
10/22/10 11:21 PM
10/22/10 11:21 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I like it! http://www.myks-tools.com/index.html
Re: Hoisting an Engine/Transmission? [Re: earlybee] #834660
10/23/10 08:45 AM
10/23/10 08:45 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
i have both a leveler,and a carb plate. i use both,dependent on room in the vehicle. the leveler usually gets real tight against the firewall, just as you are about to sit down on the motor mounts. alot of times i find it easier to sit the motor/trans in on the front hole of the carb plate(tilted tail down)sit it in,block up or rest on crossmember to take weight off the hook,then reposition the hook on the back hole,and sit the assembly in place. as for the 4 little bolts holding the whole thing up,i am a 20 year veteran toolmaker/fabricater/metalurgist, the shear-strength rating on those 4 bolts is way above the weight of a BB chrysler/727. believe me.
Re: Hoisting an Engine/Transmission? [Re: superbyrd] #834661
10/23/10 09:34 AM
10/23/10 09:34 AM
as for the 4 little bolts holding the whole thing up, the shear-strength rating on those 4 bolts is way above the weight of a BB chrysler/727. believe me.
I do but are the threads in an alum intake strong enough? I'll take your word for it if you say they are. Andy is that you in the pic
Re: Hoisting an Engine/Transmission? [Re: RapidRobert] #834662
10/23/10 09:50 AM
10/23/10 09:50 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yes they are, I've lifted motors and trannys with aluiminum manifolds scores(many) of times.
Re: Hoisting an Engine/Transmission? [Re: OrangeProwler] #834663
10/23/10 09:58 AM
10/23/10 09:58 AM
I'm convinced. On the load leveler I take off the handle & weld on a nut & use & air ratchet cause when it's in the air w a certain angle you cant turn the handle & I bolt the rear chains to not the rear intake bolts but the next pair forward so it clears the firewall
