8.8 Explorer rearend in a 69 b body #833491
10/19/10 02:44 AM
10/19/10 02:44 AM
California
Drip Offline OP
Drip  Offline OP
California
I have a 69 Sat that i have replaced the 6cyl with a 76 440. need to change the rearend also. was going to put in a 8 3/4, but have seen a few posts about putting an Explorer 8.8 in a A body. Anyone put one in a B Body. Motor will not be much over what the low comp 76 440 is. Any input would be great.
thanks
Re: 8.8 Explorer rearend in a 69 b body [Re: Drip] #833492
10/19/10 08:24 AM
10/19/10 08:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess you could make it fit if the axle tubes are long enough. I'd just go w/ a 8.75, cheap enough and it will bolt right in.
Coming soon!!!!
Re: 8.8 Explorer rearend in a 69 b body [Re: Mr.Yuck] #833493
10/19/10 09:12 AM
10/19/10 09:12 AM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I was looking into putting one under my '73.. It seemed pretty easy at first, but then when we really started looking at things, it got a little more involved. I can't remember the exact length, but on mine, with the drum brakes from an earlier explorer I would have needed to use a spring relocation kit, or wheels with less back spacing. It was also almost three inches narrower. I was going to do away with my isolator axle perches and just use the ones that held the 8.8 to the leaf springs... it even had a sway bar.
The drive shaft also come out way on the side, and my fairly new custom exhaust would have needed to be moved. On top of that, the axles are retained with C-clips, which would be okay for mild applications.. If you can, grab the drive shaft for the rear u-joint which will have to be adapted to your drive shaft, which would have to be adjusted for length, balanced and re-yoked.
In the end, it was still going to be cheaper than any 8 3/4 axle I could find, because I couldn't find any... but then the guy at the shop told me about a '73 RR parts car for sale, and it had the 8 3/4 and a ton of other stuff I needed, so I went with that.
The A-body post has two really great links I posted, very helpful stuff.... It can be done, it just boils down to how much work you want to do to get it in there.
The Blue Goose
My instagram: Bossride
Re: 8.8 Explorer rearend in a 69 b body [Re: Drip] #833494
10/19/10 03:36 PM
10/19/10 03:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Have you looked at the rear end from a Jeep Grand Cherokee?
- Stu Harmon
