Re: Weird sound in my 440
[Re: cornet684me]
#833343
10/20/10 11:30 AM
10/20/10 11:30 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
hey Bill , you may be on to something, my motor does have a windage tray, and i did drop the oil pan to fix a rear main seal leak, and to come to think of it, this noise did not start till after i fixed the rear main seal, do you think that i may not have put the windage try back on correctly?
Thats what happened to mine.No 7 rod bolt was hitting tray,heated and made an indent in the tray,put it back on and then it moved to No 6 did the same thing.Mark circled in red,same size as first one.After taking the pan off twice,no more windage tray.This is a Max wedge Motor that didn't have a tray to begin with so it really doesn't matter to me..
