Re: Weird sound in my 440 [Re: cornet684me] #833343
10/20/10 11:30 AM
10/20/10 11:30 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
hey Bill , you may be on to something, my motor does have a windage tray, and i did drop the oil pan to fix a rear main seal leak, and to come to think of it, this noise did not start till after i fixed the rear main seal, do you think that i may not have put the windage try back on correctly?
Thats what happened to mine.No 7 rod bolt was hitting tray,heated and made an indent in the tray,put it back on and then it moved to No 6 did the same thing.Mark circled in red,same size as first one.After taking the pan off twice,no more windage tray.This is a Max wedge Motor that didn't have a tray to begin with so it really doesn't matter to me..
Re: Weird sound in my 440 [Re: 62maxwgn] #833344
10/20/10 10:57 PM
10/20/10 10:57 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
looks like i will not have a windage tray either, i really do not want to pull the oil pan right now, will this problem hurt anything? it has only happened about 3times in 3.5years and only lasted about 5mins each time
Randy
Re: Weird sound in my 440 [Re: cornet684me] #833345
10/20/10 11:10 PM
10/20/10 11:10 PM
(1) but inquiring minds want to know (2) no
Re: Weird sound in my 440 [Re: RapidRobert] #833346
10/21/10 12:31 AM
10/21/10 12:31 AM
Brandon, Ms
Brandon, Ms
thanks for all the help!!! once i get it all figured out i will post the results
