Replacing Saginaw pulley #83329
07/03/08 06:14 AM
07/03/08 06:14 AM
Chicago
astat1 Offline OP
astat1  Offline OP
Chicago
I assume a pulley remover is used to get the pulley off... Does it get pressed back on or do they get tightened down with a bolt? Thanks
Re: Replacing Saginaw pulley [Re: astat1] #83330
07/03/08 06:59 AM
07/03/08 06:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes you need a puller.Most big parts stores rent them and you get your deposit back when its returned.They have an installer also.It has different threads that go in the pump snout and a bearing that tightens down on the pulley to install.Rocky
Chrysler Firepower
Re: Replacing Saginaw pulley [Re: therocks] #83331
07/03/08 11:18 AM
07/03/08 11:18 AM
None
71rm23 Offline
71rm23  Offline
None
Is there a thread on how to rebuild the Saginaw pumps?....
Re: Replacing Saginaw pulley [Re: 71rm23] #83332
07/03/08 01:45 PM
07/03/08 01:45 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
The rebuid kit I bought came with step by step instructions, nothing to tricky about the job. The tanks are really easy to bend so be careful with it.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
