Yes you need a puller.Most big parts stores rent them and you get your deposit back when its returned.They have an installer also.It has different threads that go in the pump snout and a bearing that tightens down on the pulley to install.Rocky
Is there a thread on how to rebuild the Saginaw pumps?....
