B-body 8 3/4 fit in an a-body without new axles? #833215
10/18/10 09:21 PM
10/18/10 09:21 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Can I install an 8 3/4" axle assembly into an A-body without shortening the housing? I heard all I need to do is relocate the spring perches 1/2" inboard. Can anyone confirm that? Car is a 69 Dart.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: Mike H] #833216
10/18/10 09:38 PM
10/18/10 09:38 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Yeah all you need to do is move the perches in 1/2." You'll probably need new wheels because the offset needed will be a lot different since the housing is a lot wider than an A body.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: Mike H] #833217
10/18/10 09:40 PM
10/18/10 09:40 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I just did it, I installed a 66 B body 8 3/4 into a 71 demon.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: RV2] #833218
10/18/10 10:43 PM
10/18/10 10:43 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
I put a 65 b-body 8 3/4 axle in my 72 demon.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: 440fied] #833219
10/18/10 11:21 PM
10/18/10 11:21 PM
New Jersey Bergen
rjadart Offline
rjadart  Offline
New Jersey Bergen
Did it, just pushed the springs wthout moving perches no problem was easy.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: rjadart] #833220
10/18/10 11:30 PM
10/18/10 11:30 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
I found out this is how my bbody 8 3/4 was installed in my 72 demon. I noticed some of the leaves on the springs were not centered with the other ones and stick out about 1/4"....just curious if yours did anything similar?
I need my pinion angle changed so I'll probably just move the perches in when I do that.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: rjadart] #833221
10/18/10 11:32 PM
10/18/10 11:32 PM
Under My Car
Mopar_Country Offline
Under My Car
Did it, just pushed the springs without moving perches no problem was easy.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: Mopar_Country] #833222
10/19/10 12:00 AM
10/19/10 12:00 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Keep in mind that the 68-70 B body axle is the widest of the B body axles until 1971. The Demon, Duster and Dart Sport have rear wheel arches up higher on the bodyline, allowing more tire clearance than a standard sedan/hardtop Dart or Valiant. Comparing axle fitment on a Demon VS a Dart isnt completely fair. There is a spec chart of axle widths on this site. Check it out.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: Kern Dog] #833223
10/19/10 10:45 AM
10/19/10 10:45 AM
New Jersey Bergen
rjadart Offline
rjadart  Offline
New Jersey Bergen
Used new springs, bushings, ect no problem with just pushing springs to fit see no issues.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: rjadart] #833224
10/19/10 12:13 PM
10/19/10 12:13 PM
Under My Car
Under My Car
Yet.
Re: B-body 8 3/4 fit in an a-body without new axles? [Re: Mopar_Country] #833225
10/19/10 12:50 PM
10/19/10 12:50 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I recently read a article (maybe at Allpar) about the design of the Duster. The designers really stuck their necks out on the car...truly risked their careers.
One thing I found interesting was that the designers planned for the rear axle to be 2" wider than what was produced.
'71 Duster
