8-3/4" axle bearings #832858
10/18/10 02:23 PM
10/18/10 02:23 PM
New Braunfels, TX
BigBlockScamp Offline OP
New Braunfels, TX
Has anyone had success repacking 8-3/4" axle bearings with the bearings on the axle? Typically I pack a new bearing prior to pressing it onto the axle but I've got a pair of bearings that are looking a little dry and would prefer to repack them instead of replacing them.
Thanks.
Re: 8-3/4" axle bearings [Re: BigBlockScamp] #832859
10/18/10 02:39 PM
10/18/10 02:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It is/was done every day. Get your self a needle for your grease gun and pack grease between every roller and smear it around the surface before installing.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8-3/4" axle bearings [Re: MoparforLife] #832860
10/18/10 04:23 PM
10/18/10 04:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
X2, flush it out first with brake wash and blow it out with compressed air.
Re: 8-3/4" axle bearings [Re: JohnRR] #832861
10/18/10 04:59 PM
10/18/10 04:59 PM
scratchnfotraction Offline
i use a greese needle on the front inner wheel bearing as well to save the seal
I do it every time the brakes/rotor is off
even greese a few NON-greeseable tie rod/ball joints with the needle thru the rubber boot
well worth the couple $$ for it at the auto store
Re: 8-3/4" axle bearings [Re: scratchnfotraction] #832862
10/18/10 07:43 PM
10/18/10 07:43 PM
clean it w solvent/final clean w starting fluid (my fav)/What they said, the needle works great
Re: 8-3/4" axle bearings [Re: RapidRobert] #832863
10/19/10 02:06 PM
10/19/10 02:06 PM
New Braunfels, TX
New Braunfels, TX
Great, thanks for all the replies! I'll give it a try.
