Torsion bars which way #832816
10/18/10 01:28 PM
10/18/10 01:28 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I had my T bars out to try drag bars and want to put them back in!! They are marked left and right but which way is the back???? (or front??)
Thanks in advance!!
Re: Torsion bars which way [Re: Dodgem] #832817
10/18/10 01:56 PM
10/18/10 01:56 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
No differance between front and back.
Re: Torsion bars which way [Re: txterry2] #832818
10/18/10 02:01 PM
10/18/10 02:01 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks so they don't matter which way they get twisted?? so it would not matter if they were in the right or left sides then either??
Re: Torsion bars which way [Re: Dodgem] #832819
10/18/10 02:23 PM
10/18/10 02:23 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
No answer for you but I have always wondered the same thing! They say there is a left and right and they need to be on the correct side, but it doesn't matter which end goes in first.
Maybe I'm slow, but that doesn't make sense to me. Putting different ends in first would make them twist in different directions...and I understand that they are made to twist in a specific direction.
I've never seen (not saying there isn't one) an explanation as to why they are not specific as to which end goes in first...
Hopefully someone can chime in.
Re: Torsion bars which way [Re: Bdrainy] #832820
10/18/10 02:32 PM
10/18/10 02:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They twist in the same dirrecting no matter what end is in the front. You need to get them on the correct side of the car though.
Re: Torsion bars which way [Re: Bdrainy] #832821
10/18/10 02:46 PM
10/18/10 02:46 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Me two Left bar in driver side end A is in the driver lower control it gets twisted counter clockwise looking from front and end B in back looking from back would be twisted clockwise.
switch around now with B end in front it would now be twisted counter clockwise and A in back would have clockwise twist???
Re: Torsion bars which way [Re: Dodgem] #832822
10/18/10 02:50 PM
10/18/10 02:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They still twist in the same dirrection.
Re: Torsion bars which way [Re: burdar] #832823
10/18/10 02:59 PM
10/18/10 02:59 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Picture putting the lid on a bottle. No matter whether you're holding the cap or the bottle in your right hand, you're still turning your right hand clockwise to tighten the lid. It's no different with the torsion bar.
Re: Torsion bars which way [Re: Fab64] #832824
10/18/10 09:05 PM
10/18/10 09:05 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
But if you glued to milk bottles together at the bottom (assumimg screw on caps) and put the cap ends in a vise and turned whole thing one would tighten while the other tried to loosen???
Re: Torsion bars which way [Re: Dodgem] #832825
10/18/10 09:13 PM
10/18/10 09:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I started an argument YEARS ago with my high school auto theory teacher when he told the class that the reason for a stud with right hand threads on one end and left hand threads on opposite ends, was for applications such as 2 piece cue stick. I told him he was full of it, and the class wasted another hour on the subject, and teach finally agreed he was wrong.
Re: Torsion bars which way [Re: buildanother] #832826
10/18/10 09:19 PM
10/18/10 09:19 PM
Put the end w the #'s/letters to the rear so later on down the line you can see it to refer to it if you forget whats in there as the front ends will be covered
Re: Torsion bars which way [Re: RapidRobert] #832827
10/18/10 10:11 PM
10/18/10 10:11 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
My T bars have numbers on both ends?? MP 920's
Re: Torsion bars which way [Re: Dodgem] #832828
10/18/10 10:38 PM
10/18/10 10:38 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I would like to know what happens if you put them on the wrong side? What problems would you have?
Raul
Re: Torsion bars which way [Re: Dodgem] #832829
10/18/10 10:40 PM
10/18/10 10:40 PM
in that case either way end to end will work for you. Some of the real large bars (I dont know about MP ones) can even go on either side (but keep it on the same side always) as they are not marked side specific. EDIT no R or L just 920 right?
Re: Torsion bars which way [Re: Dodgem] #832830
10/18/10 10:46 PM
10/18/10 10:46 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Actually, you proved my point. What I'm trying to say is that just because you swap the ends front to rear, the direction needed to tighten the lid doesn't change. Pretend the glued-together bottles are the passenger side torsion bar. The LCA is attached to one cap, and the other cap is in the torsion bar anchor. When the passenger side wheel comes up, the cap is going to tighten. Even if you swap them end for end, it will work the same way.
Re: Torsion bars which way [Re: Fab64] #832831
10/18/10 11:01 PM
10/18/10 11:01 PM
If a Tbar was suspended in air & you walked up on it from the side and extended your arms and grabbed the left end w your left hand and the right end w your right hand then applied a bit of torque to each end clockwise & held it on both ends then turned (rotated) your body around halfway a half turn you'd still be applying torque to each end the same way (clockwise)so the bar would still be getting twisted the same way
Re: Torsion bars which way [Re: RapidRobert] #832832
10/19/10 12:43 AM
10/19/10 12:43 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Guess I'm trying to look at it from two pivot points when one is anchored.
Re: Torsion bars which way [Re: RapidRobert] #832833
10/20/10 02:07 PM
10/20/10 02:07 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
No they have a full set of numbers different front and back and R and L
Re: Torsion bars which way [Re: Dodgem] #832834
10/20/10 05:39 PM
10/20/10 05:39 PM
Post what you have on each end. (all 4 of em!)
Re: Torsion bars which way [Re: RapidRobert] #832835
10/20/10 07:49 PM
10/20/10 07:49 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Numbers with the L or R to the rear, thats how I remember it anyway.
