Oil plug on the back of 318 #832799
10/18/10 12:30 PM
10/18/10 12:30 PM
Michgian
moparfun340 Offline OP
Michgian
I can not get the oil plugs out of the back of my 318. They are for the lift galley. They are a pipe plug with a square inside and a 3/8 ratchet will not go into it to get it out. Could you please let me know what I need to use?
Re: Oil plug on the back of 318 [Re: moparfun340] #832800
10/18/10 05:04 PM
10/18/10 05:04 PM
scratchnfotraction Offline
I have ground down a 3/8 extention to fit
I also used a torch to get it cherry red and then hit it with the 3/8 drive air hammer with extention
after they are out,and you buy a complete core plug kit(I prefer brass core plugs for the block)those are replaced with allen plugs that a regular allen wrench fits
i have the part # at home for a complete kit,which also comes with a oil pump drive bushing for the block as well
I will post it later
Re: Oil plug on the back of 318 [Re: moparfun340] #832801
10/18/10 06:55 PM
10/18/10 06:55 PM
grab a bolt & turn it into a square by hitting all 4 sides w your bench grinder
Re: Oil plug on the back of 318 [Re: moparfun340] #832802
10/18/10 08:20 PM
10/18/10 08:20 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I just happened to have this 5/16" square key ( I think it was the crank key on a 260 olds that I scrapped) and a broken 3/8" drive socket so I welded part of the key to the socket. Works good but I probably won't be able to find it next time I need it.
Re: Oil plug on the back of 318 [Re: moparfun340] #832803
10/18/10 09:11 PM
10/18/10 09:11 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Sears has them. Harbor Frieght has disposable ones.
Harbor calls them drain plug sockets. Sears calls them pipe plug sockets. Hard to find without the proper name.
Craig
