2004 Dodge srtatus 2.7 overheating???
#832256
10/17/10 08:00 PM
10/17/10 08:00 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
our dodge has 140,000 miles and has just started to over heat. put in a thermoustat (190), and also found a cracked plastic housing on top of the engine, also replaced. it still over heats. I had a friend do this as I was out of town. till fri. we picked it up sat and it overheated on the way to town, any advise would be appreciated.
HEMI,S ARE FOREVER!!!
Re: 2004 Dodge srtatus 2.7 overheating???
[Re: Pacnorthcuda]
#832259
10/17/10 08:58 PM
10/17/10 08:58 PM
1969 HEMI R-T
West Central Wi.
never had a w pump or timing belt. it is boiling the coolant in the tank (overflow), and the coolant is very dirty now! was clean when he started, and when we redid it today, we also ellevated the front end when we put in the coolanttoday. also did a chemical test on it for head gasket(3) times to be sure, was fine. and a vac test all where fine. I am at a loss. I am very inexperienced with newer cars. also the car is fine on the flat, but temp climes on a hill
[Re: 1969 HEMI R-T]
#832260
10/17/10 09:32 PM
10/17/10 09:32 PM
Posts: 8,028 The Grand State of Confusion-O...
SKR8PN
The 2.7 is not a timing belt engine, it is a timing CHAIN design. The water pump is driven by the chain and is INSIDE the timing cover. Might wanna check the oil, the oil cap and dipstick for any signs of coolant. If you do find a brown gooey substance inside any of those areas, have the water pump checked ASAP. The chains & guides need to be checked(and probably replaced) at the same time. Welcome to the world of 2.7 ownership.
Karma has no menu. You get served what you deserve.
[Re: SKR8PN]
#832262
10/17/10 09:47 PM
10/17/10 09:47 PM
1969 HEMI R-T
West Central Wi.
we checked the oil and it was ok. I just rechecked it all looks good. I was thinking of the water pump. any way to be sure of this? herd they will ware through the housing! first I have herd of this. but I have little experience with these.
[Re: 1969 HEMI R-T]
#832263
10/17/10 09:52 PM
10/17/10 09:52 PM
1969 HEMI R-T
West Central Wi.
he showed me the print out of the assy procidure. he said he did it correctly. vent hole up. we burped it and double checked it. if this is correct. how do you get all of the air out. I was careful with it when driving it I do not think we hurt it. the fans are coming on at around 210.
[Re: 1969 HEMI R-T]
#832264
10/17/10 09:59 PM
10/17/10 09:59 PM
Posts: 2,592 None
71rm23
None
Just keep repeating the process and check the coolant at the same time. I also cycled the temp gauge to hot, like turning the heat on, with the fan on as well. Crack the valve with it running, close it, open again, and so on. Til you see no more bubling from the valve. Service coolant.
I changed my radiator on mine this last July. It took a while to do (to burp, or get the air out). Why? A lady pulled out in front of me July 4th and raining outside. Either I hit her or swerve. I swereved and slid into a curb, cracking the radiator.
[Re: 71rm23]
#832265
10/17/10 10:07 PM
10/17/10 10:07 PM
1969 HEMI R-T
West Central Wi.
ouch! sorry to here about that, glad your OK! sounds like it cuold have been worse. I have had no experience with these 2.7 engines and neither has mike my buddy. H eis very sharp. and has almost every tool in the bizz. he has never had a problem this persistant! and neither have I. I will keep bleasding it and see where it gets me! thanks for the input
