Re: Torsion Bars Help
[Re: Crock]
#831944
10/17/10 03:50 PM
10/17/10 03:50 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The T-bars are the "coil springs" in a Mopar front end.A torsion bar is basically a unwound coil spring.The alignment shop probably adjusted the ride height to the factory specs and then aligned the front end.Don't know what you use for a rear suspension,but S/S springs usually will make the car sit higher in the rear.
