Thermoquad leaking #83173
07/02/08 05:04 PM
07/02/08 05:04 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
i checked the two things recommended by you guys here:
- jet wells are good
- O rings were in place and looked good, too
any other ideas what could be causing the fuel leaking and dripping from the primary throttle shaft?
btw. anyone heard anything from Demonsizzler lately? it has been a while that he posted here and i couldnt get hold of him by phone or mail yet ...
Re: Thermoquad leaking [Re: 440sat72] #83174
07/02/08 05:33 PM
07/02/08 05:33 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Is there any play in the throttle shaft? Worn bushings can drip fuel as well if they are REALLY bad, but then Im sure you would have a big enough vacuum leak you probably would have been aware of that.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Thermoquad leaking [Re: 69L78Nova] #83175
07/02/08 06:32 PM
07/02/08 06:32 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Floats set too high
Re: Thermoquad leaking [Re: 440trk] #83176
07/02/08 11:27 PM
07/02/08 11:27 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The main problem with those carbs is the platic center section. They tend to warp. I've ran one across a fine piece of sand paper to get rid of a a small warping problem. As far as fuel leaking from the throttle shaft. Sorry
Re: Thermoquad leaking [Re: 69L78Nova] #83177
07/03/08 02:45 AM
07/03/08 02:45 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
how would i check for that? are the bushings available?
