1973 Cuda Distributor Swap #831682
10/17/10 09:32 AM
10/17/10 09:32 AM
Iowa
FRCUDA Offline OP
FRCUDA  Offline OP
Iowa
I just did an engine swap on a 1973 Cuda which had electronic ignition. The new motor has a HEI distrbutor from D.U.I. My question is what modifications need to be made to the wiring harness to get the alternator to work and get a wire that is hot on ignition and run to hook to the new distrbutor
Re: 1973 Cuda Distributor Swap [Re: FRCUDA] #831683
10/17/10 10:12 AM
10/17/10 10:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Shouldn't need to do anything for the alternator, unless you forgot to mention something in your post. You should be able to use the feed side of the ballast resistor for your DUI setup, not sure how you would tie the 12v in start line into it short of using a diode to prevent back feed.
Don't be the exception.
Re: 1973 Cuda Distributor Swap [Re: Supercuda] #831684
10/17/10 09:41 PM
10/17/10 09:41 PM
Iowa
FRCUDA Offline OP
FRCUDA  Offline OP
Iowa
Thanks Supercuda
