Re: fuel flow
[Re: jjl]
#831334
10/17/10 10:51 AM
10/17/10 10:51 AM
RapidRobert
I think the eccentric for the mech. pump is worn or broke,depending on the style.
sometimes a worn mech pump (even a new one) has a hard time self priming (but you did have gas for awhile)& will not put out enough vol w cranking but will once it's running w the worn pumps' arm being stroked faster. How hard is the eccentric on this non Mopar to get to, to eyeball it? I sure think that'd be easier/cheaper/quieter than plumbing in an elec. Good luck w it. EDIT I'd slap on a new $20 pump & give it a shot
