JB weld to fix a casting flaw? #83059
07/02/08 02:24 PM
07/02/08 02:24 PM
RapidRobert Offline OP
915 heads. the divider in between one pair of intake ports has flaws & is missing material & needs to be built up. Would JB be OK for this & if not would you guys recommend anything else? Thank you for your time.
Re: JB weld to fix a casting flaw? [Re: RapidRobert] #83060
07/02/08 03:08 PM
07/02/08 03:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've seen a lot tougher stuff than that fixed with JB Weld. Go for it.
Re: JB weld to fix a casting flaw? [Re: RapidRobert] #83061
07/02/08 03:15 PM
07/02/08 03:15 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
PM RyanJ and ask him what he uses in ports. I remember him saying that the stuff that he uses(not JB Weld) is bulletproof. -Bob
Re: JB weld to fix a casting flaw? [Re: BobR] #83062
07/02/08 04:42 PM
07/02/08 04:42 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
if something is bullet proof they'll just make better bullets ...
that aside Moroso A B epoxy ...
but JB weld will probably work also .
Re: JB weld to fix a casting flaw? [Re: JohnRR] #83063
07/02/08 08:04 PM
07/02/08 08:04 PM
thank you guys.
Re: JB weld to fix a casting flaw? [Re: BobR] #83064
07/03/08 12:41 AM
07/03/08 12:41 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
JB is good on the outside cracks, But not IN the ports where it can do some damage if it comes loose.
Re: JB weld to fix a casting flaw? [Re: earlybee] #83065
07/03/08 12:50 AM
07/03/08 12:50 AM
I am going to get ahold of ryanj
Re: JB weld to fix a casting flaw? [Re: RapidRobert] #83066
07/03/08 07:51 AM
07/03/08 07:51 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We use a bowling ball epoxy here at work. We order it from a place called Baker & Collinson 1-313-366-2100. Not cheap though, its like $150.00 for a 1 gal. unit part A & B.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
