4 bolt master CLY and brackets to a 2 bolt #830471
10/15/10 02:54 PM
10/15/10 02:54 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
hello, i am in need of the master cly bracket, I want to bolt a 2 bolt mc to a 4 bolt location for my 68 dart.. will this bracket work with pwer brakes? cause i may add pwer later..right now its Manual disc brakes
Re: 4 bolt master CLY and brackets to a 2 bolt [Re: Dakota_Don] #830472
10/15/10 09:29 PM
10/15/10 09:29 PM
BDW Offline
BDW  Offline
Re: 4 bolt master CLY and brackets to a 2 bolt [Re: BDW] #830473
10/16/10 01:19 AM
10/16/10 01:19 AM
Alton, IL
Alton, IL
thanks
Re: 4 bolt master CLY and brackets to a 2 bolt [Re: Dakota_Don] #830474
10/16/10 03:36 PM
10/16/10 03:36 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
mopar makes one
part number p5249315
Re: 4 bolt master CLY and brackets to a 2 bolt [Re: rhad] #830475
10/16/10 03:54 PM
10/16/10 03:54 PM
wv
dakster Offline
dakster  Offline
wv
Re: 4 bolt master CLY and brackets to a 2 bolt [Re: dakster] #830476
10/16/10 08:29 PM
10/16/10 08:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'm not sure about the AR engineering adapter but I put the Mopar adapter on my wife's 72 charger's power booster.
I had to grind the corners of the adapter a little to fit the booster and then plenty of trial and error with readjusting the push rod int the booster so it would reach into the MC.
I used rear end marking compound on the tip of the push rod, installed the master on to it (tight as if it were installed) and then took it apart to check how much transfer I had.
Adjust until the transfer goes away and then bring the adjuster back slowly until it barley contacts or maybe even a slight gap.
Best pic I have
