'67 B-body, wheel and tire combo?
#830144
10/15/10 03:07 AM
10/15/10 03:07 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Hi All, Time for some new wheels and tires for the car. I'd really like to put on some 275/60/15 drag radials. I've read of people having success with this without having to minitub, but only with the right rims/backspacing. Will a 15x8 with 4.5" backspace get a 275/60/15 drag radial under the car? If 275/60/15 is too tough, what would be the next best size? I did look at all this a few years ago, and worked out exactly what I wanted, but can neither remember what was decided nor find record of it. And what about the front wheels, what would be well matched rim and tyre sizes? Cheers!
Re: '67 B-body, wheel and tire combo?
[Re: Jeff_383]
#830147
10/15/10 09:48 PM
10/15/10 09:48 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
275 will likely fit, if on a 15x7 rim. The 8" rim might let the section width get into the wheel lip ??. If you're just talking drag strip, I'd feel safe going that route. IF the car is going to be street driven (over bumps and around corners at speed), 275's might rub. Your ride ht. will come into play here as well. MT makes the ET drag radial in a 255. That will fit no problems for sure.
[Re: Jeff_383]
#830148
10/15/10 11:21 PM
10/15/10 11:21 PM
Posts: 372 PA
moparboy66
PA
I have 275/60 drag radials on 15x7 rims with 4 3/8" BS on my 67. No wheel well mods. I know not ideal size rim, but it works. My fronts are 15x5.5 with 205/75's.
I love your look there Jeff!
[Re: belvedere1967]
#830151
10/17/10 01:05 AM
10/17/10 01:05 AM
StealthWedge67
Puyallup, WA
I think the 255's are the right choice for these cars. Hard to argue with Jeffs look, though.
[Re: Mr.Yuck]
#830156
10/18/10 08:27 AM
10/18/10 08:27 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I used a 275/60/15 in the back on a 15x7 and a 215/75/15 up front on a 15x6.
[Re: Jeff_383]
#830161
10/19/10 12:15 AM
10/19/10 12:15 AM
StealthWedge67
Puyallup, WA
One last thing to consider: If the car does hook good with the 255's, Its likely that it will be a hair faster in 60' than it will on 275's, as the slightly smaller diameter effectivly lowers your gearing just a bit.
[Re: Hemi_Ram]
#830163
10/20/10 10:34 PM
10/20/10 10:34 PM
Damned67
Tomorrow.
Hemi Ram, That car looks really sharp with those wheels! Any wheel well mods to the rear? And do you happen to know what the backspacing is on the rims? Cheers!
