battery swelling #829919
10/14/10 08:50 PM
10/14/10 08:50 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
What causes the case of a battery to bulge.
It is pushed out. Is the Alt overcharging?
Re: battery swelling [Re: moparmikethree] #829920
10/14/10 08:54 PM
10/14/10 08:54 PM
Kirkland, Washington
Pacnorthcuda Offline
Either excessive heat or a deeply sulphated battery--so sulphated that the deposits have litterally pressed hard against the case.
Re: battery swelling [Re: Pacnorthcuda] #829921
10/14/10 09:00 PM
10/14/10 09:00 PM
This is on a customers car. It had 2 new batterys in 2 months
Re: battery swelling [Re: moparmikethree] #829922
10/14/10 09:05 PM
10/14/10 09:05 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
It's over charging alot. Regulator stuck open and alternator running full tilt. Should also be able to smell the battery cooking after a long drive.Stick a volt meter across it and bring the rpm's up some and the volt meter will probally get up over 16/17 volts no problem.....needs only 13.8 or so while driving.
Re: battery swelling [Re: a4runer] #829923
10/14/10 10:13 PM
10/14/10 10:13 PM
Berlin, WI
safetymike1977 Offline
Berlin, WI
Watch out... Probably close to the point where it could explode...
Re: battery swelling [Re: safetymike1977] #829924
10/15/10 03:45 AM
10/15/10 03:45 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Roger that. Something's overcharging the battery- most likely the voltage regulator has failed.
What make/model/year vehicle?
Re: battery swelling [Re: In_The_Pink] #829925
10/15/10 12:49 PM
10/15/10 12:49 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Hold down bracket on top too tight? What car is it?
Re: battery swelling [Re: CYACOP] #829926
10/15/10 01:20 PM
10/15/10 01:20 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Re: battery swelling [Re: a4runer] #829927
10/15/10 01:28 PM
10/15/10 01:28 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Exactly. 13.8 volts is max the regulator should let the alternator charge. Probably cooked that battery too. New regulator definitely, and probably a new battery now.
