E85 vs Petrol
#829745
10/14/10 05:04 PM
10/14/10 05:04 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Any engine building considerations? I understand it runs a little cooler..and you consume 30% more. Better for forced induction..? Would appreciate anyone sharing their experiences of making the switch.
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: E85 vs Petrol
[Re: HEMIFRED]
#829747
10/14/10 05:28 PM
10/14/10 05:28 PM
Keith Black®
QLD Australia
In Australia we are only just getting E85. Hence the decision.
Just looking for tips from people who have already made the change .. benefits, things to look out for.
Re: E85 vs Petrol
[Re: Keith Black®]
#829748
10/14/10 05:38 PM
10/14/10 05:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For us over here the major factor is the cost... its about $.20 cheaper than the regular pump gas plus you get the added octane(about 105)... yes alot of turbo guys are running on it... I've been very happy running it... the car is very consistent on it
Re: E85 vs Petrol
[Re: ajcasini]
#829751
10/14/10 09:13 PM
10/14/10 09:13 PM
Posts: 16,930 NC
440Jim
NC
2. When choosing cams be sure not to get anything with a wide LSA. You want the LSA to be at or less than 110.
I tested with E85 and a 112 LSA cam and was happy with it. When I changed the combo the next year I went to a bigger cam (combo reasons, not E85) and it happened to be 110 LSA.
The fuel pump is a consideration. Ethanol is not as bad as methanol, but material properties for long term operation should be considered. And the flow rate increase.
I have found that E85 is between gasoline and methanol in many ways. And I like the result.
I am running 13.5 CR naturally aspirated, aluminum heads, 0.039" quench, 279/280 at 0.050" duration cam.
Re: E85 vs Petrol
[Re: 440Jim]
#829752
10/14/10 10:07 PM
10/14/10 10:07 PM
MR_P_BODY
I'm running a 112 lsa cam also
Re: E85 vs Petrol
[Re: MR_P_BODY]
#829753
10/15/10 01:05 AM
10/15/10 01:05 AM
Keith Black®
QLD Australia
thanks looks like its the right option. cooling is important as is intercooling in my build It looks like a good option. I hope the fuel pump (AeroM 11104) will keep up but mostly street use so should be ok. EFI.. so tunable. appreciate your comments. thanks everyone.
