Pressure plates: how much is too much ? #82941
07/02/08 12:13 AM
07/02/08 12:13 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
At what clamping force does a pressure plate become start to create a stiff pedal ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Pressure plates: how much is too much ? [Re: AlexP] #82942
07/02/08 09:25 AM
07/02/08 09:25 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Bump for the morning crew.
Re: Pressure plates: how much is too much ? [Re: AlexP] #82943
07/02/08 10:07 AM
07/02/08 10:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think it comes down to how much of a "man" are you,.......some guys complain about 2200 lbs!......I've been running a 3400 lb BorgBeck design in my Challenger T/A for the last 15 years,.....someguys can't even squeeze the pedal down on it.....they think I'm ......but I like it because the "hook-up" is awesome......but you have to beef up all the linkage system,....otherwise things start to shear!
My Daytona on the other hand has a Keisler TKO 5spd with a hydualic throwout w/ a 2800 lb Sachs B/B style......the pedal effort is almost non-exsistant.......the hydualic set up is nice, although you lose the "feel" that a "real" pedal gives you!.......I think your focus is best aimed at what your driveline needs are, what are the intended uses of the car,.....there are many set-ups to address any need?......so there's a lot of variables to your question,......everyones gonna have a different opinion on what to run?
Re: Pressure plates: how much is too much ? [Re: DAYCLONA] #82944
07/02/08 11:04 AM
07/02/08 11:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Pressure plates: how much is too much ? [Re: JohnRR] #82945
07/02/08 11:41 AM
07/02/08 11:41 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
It will be a hot street car, but the chassis is not set up for drag racing. It will never hook and I'm not getting a Dana anytime soon, but I do intend to wring the combination out as much as the 23 spline will let me.
A. 9.4:1 .484 cammed 383, 915 heads/DP4B, 1 7/8" hookers, 650 dp and 3.91 SG outback on in a 68 Roadrunner with lots of chassis stiffening and handling upgrades.
I tried driving a new civic si with a really touchy hydraulic clutch and I just couldn't launch or do much of anything right. I get in a 68 charger with a really stiff pressure plate combo and I can powershift and haul around with no issues.
Re: Pressure plates: how much is too much ? [Re: AlexP] #82946
07/02/08 11:49 AM
07/02/08 11:49 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You're probably a good candidate for something around 3400lbs, then.
Rich H.
Esse Quam Videri
Re: Pressure plates: how much is too much ? [Re: DAYCLONA] #82947
07/02/08 12:02 PM
07/02/08 12:02 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Pedal can be gotten used to. I switched from power brakes to a big bore manual brake setup, thought about switching to something else after it first got in. Pedal doesn't seem even 'firm' anymore...you'll get used to it.
Re: Pressure plates: how much is too much ? [Re: GoodysGotaCuda] #82948
07/02/08 12:07 PM
07/02/08 12:07 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Haven't bought one in a long time, but the clutch disc that direct connection/mopar performance sold was a great piece too. Hooked hard and lasted at least for a hot street car.
Re: Pressure plates: how much is too much ? [Re: farmington] #82949
07/02/08 12:13 PM
07/02/08 12:13 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
My scamp has power brakes but I barely drove it.
I went right into driving my RR with manual brakes with no issues, but it was a manual brake car to begin with.
Re: Pressure plates: how much is too much ? [Re: AlexP] #82950
07/02/08 05:10 PM
07/02/08 05:10 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If you are looking for decent clamping force without the big pedal pressure, look into a Centerforce.
