Re: Big Block Timing Set: who makes a good one ?
[Re: moparsquid]
#829349
10/14/10 01:00 AM
10/14/10 01:00 AM
RapidRobert
I need one too and heard good reviews on Cloyes also
[Re: RapidRobert]
#829350
10/14/10 01:06 AM
10/14/10 01:06 AM
Posts: 565 IA
landon1
IA
i think mine was $45 - comp double roller
'71 Satellite Sebring 440
[Re: landon1]
#829352
10/14/10 10:16 AM
10/14/10 10:16 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
I just bought a comp double roller, BAD design, instead of it having a hole for the dowel pin on the cam it had a SLOT about .625 long, I didn't measure it , but the dowel was in the middle of the slot. I needed to advance the cam about 4 degrees and the 4 degrees that you can move it in either direction is CRANK degrees which moves the cam 8 degrees which makes zero sense ... all the adjustable with plus and minus 4 degrees do this and have done it forever ... HELLO MCFLY ???
Anyway whatever set you get make sure it has a hole for the dowel not a slot and make sure you degree it because not all markings are the same. I put 2 different chains on the same cam and they were 1 degree different from each other.
The best to get is a billet with 9 adjustment keyways, at least with those you can move the cam 4 degrees or a single and use a bushing , chevy bushings are the same for mopar and easy to get locally.
And good luck getting anything local other than a stock replacement set the same day.
