Carb size on 340
#829240
10/13/10 10:34 PM
10/13/10 10:34 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Hey guys what would be a good size carb for a hot 340 setup for the steet?
Plans are 340 .030 over with ported and polished J heads with 2.05 intake and 1.60 stainless longer than stock valves, 62 cc polished chambers,W2 style rocker setup with 273 adjustable 1.5 rockers, TRW flat tops around 10.3:1 compression, Comp XE274 solid lifter cam, prted Edelbrock T5 intake or Air gap copy,1 5/8 ceramic coated Hooker headers to 2 1/2 exhaust through chambered mufflers and dumped before axle.
All in a 72 Duster with a 4 speed, 3:91 rear and 28" tall drag radials. I have a Holley 650 vac secondary carb on my 318 now, will that do or should I set up to a 650 or 750 double pumper mechanical secondary carb?
Hoping for a little over 400HP, the desktop dyno and comps dyno both have it at 450hp 435Tq. What do you think for a carb?
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Carb size on 340
[Re: ademon]
#829242
10/13/10 11:27 PM
10/13/10 11:27 PM
440Satellite
super gas
super gas
Hazlet, NJ
Yeah I was thinking 450 sounded awful high, thats why I said I was hoping for a little more than 400hp. Might go bigger cam if my compression ends up being closer to 10.5:1 to bleed off some pressure. Just starting to peice it all together. The motor I got had TRW dome pistons and looks like it was at 12:1, going for pump gas now so gotta tame it down a bit.
So you think the 650 Holley will be too small, a 750DP would be better? Thanks
Butch
1972 Duster
318 4 speed
[Re: RapidRobert]
#829244
10/14/10 07:09 AM
10/14/10 07:09 AM
440Satellite
super gas
super gas
Hazlet, NJ
I forget, I'll have to look tonight after work. Motor probably wont be ready to go in the car till spring so I have time, but I figure if I come across a good deal on the right sized carb I can jump on it if I know what a good size is.
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#829245
10/14/10 07:46 AM
10/14/10 07:46 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
On the below 340, my last carb was a Promax 650 vac sec and it ran good. I would say that it is a good all around cruising carb that definately out performed my Edy 600 and 750cfm units by a long shot. My current carb is a QF Super Street 750cfm Annular (735cfm actual) DP and the response from this carb is much crisper than the 650 vacuum secondary unit.
I would definately suggest a 750-ish DP on your build!!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#829246
10/14/10 08:23 AM
10/14/10 08:23 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I ran a 750HP on my old 340 swinger, much milder motor than yours and it ran perfect. I thik I had 28 squirters, 72-80 jets. .030 over 340, Mild ported J heads, stock 340 cam, 1.6 roller rockers, RPM air gap, TTi headers, auto 3.55's. Car ran 13.80 w/ the holley and 14.02 w/ a carter 625. I like 750Dp's very tunable for whatever your application.
[Re: dustergirl340]
#829248
10/14/10 06:21 PM
10/14/10 06:21 PM
440Satellite
super gas
super gas
Hazlet, NJ
Thanks everyone. I quess I'll pick up a 750 DP if I find a good deal on it, otherwize I'll try out the 650 and see what it does. Raining here so I cant check the #'s. but is there anything you can do to a 650 to improve flow? Also can they be converted to a double pumper?
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#829249
10/14/10 08:58 PM
10/14/10 08:58 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
The 650 would probably keep up with the 750 up until 5000 rpm or better. So for the street you may not need 750.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#829250
10/14/10 09:34 PM
10/14/10 09:34 PM
440Satellite
super gas
super gas
Hazlet, NJ
Planning on a couple trips a year to the strip to have some fun once it finished, so I quess a 750 DP could help.
Butch
1972 Duster
318 4 speed
