hiding electronic ignition box ,where's a good place?? #82903
07/01/08 10:13 PM
07/01/08 10:13 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
instead of running dual points in my AAR ,i'm going with electronic. where's there a good place to hide the box? or is a big deal and mount it on the fire wall?? thought it would look better hiding it some where easy?? thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: hiding electronic ignition box ,where's a good plac [Re: hulmule] #82904
07/01/08 10:51 PM
07/01/08 10:51 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Under the battery tray, under a hollowed-out windshield washer jar, inside the car under or behind the glovebox, or mounted to a custom bracket that uses existing holes. Running the wiring alongside an existing harness helps hide that part. It's generally considered a good idea to keep those units cool or at least have airflow past them. Personally I'm against drilling holes in cars, and the less clutter in an engine compartment, the better it looks to me.
Re: hiding electronic ignition box ,where's a good plac [Re: topside] #82905
07/01/08 11:15 PM
07/01/08 11:15 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I put mine under the battery tray. This way no need to drill any holes in the body and the box is readily accessible. I extended the wiring and wrapped it toghether with the existing harness. Works perfect.
Re: hiding electronic ignition box ,where's a good plac [Re: Barnabas_Kriss] #82906
07/02/08 07:44 AM
07/02/08 07:44 AM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
sounds like the battery tray to me!! just need to extend the wires.!!thanks guys
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: hiding electronic ignition box ,where's a good plac [Re: hulmule] #82907
07/02/08 09:55 AM
07/02/08 09:55 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Remember, adding length to the wiring harness will eventually degrade the circuit . It was orginally designed to operate at a certain length wiring harness and extending this length changes the pattern if observed on a lab scope
Re: hiding electronic ignition box ,where's a good plac [Re: gtx6970] #82908
07/02/08 10:30 AM
07/02/08 10:30 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I put mine in the cavity behind the right front headlight and in front of the rad support. I just had my engine wiring harness made so the wire just extends beyond the washer pump down under the frame rail and into the cavity behind the headlight.
Re: hiding electronic ignition box ,where's a good place?? [Re: hulmule] #82909
07/02/08 10:53 AM
07/02/08 10:53 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I like putting them inside the car then run the wires back through the firewall
CHECK OUT MY NEW WEB SITE !
Re: hiding electronic ignition box ,where's a good place?? [Re: anlauto] #82910
07/02/08 12:16 PM
07/02/08 12:16 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
use a petronix ignition.... two wires and uses your original ditributor with correct advance curve.
Re: hiding electronic ignition box ,where's a good place?? [Re: JRepucci] #82911
07/02/08 10:39 PM
07/02/08 10:39 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I hid a Jacobs Ignition box in the same place as GYGeneral,and nobody ever saw it.
Re: hiding electronic ignition box ,where's a good place?? [Re: anlauto] #82912
07/03/08 08:31 AM
07/03/08 08:31 AM
Buckle of corn belt ,c. lll.
420SIX Offline
420SIX  Offline
I put my rev limiter on top of heater box. Ran power from fuse block, and an unused terminal in bulk head connector for the engine wire
Re: hiding electronic ignition box ,where's a good plac [Re: gtx6970] #82913
07/03/08 10:10 AM
07/03/08 10:10 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I find that hard to believe. At 6000 RPM on an 8 cyl. motor, that's only 48kHz. A few straight feet of wire isn't going to do s#!t.
Re: hiding electronic ignition box ,where's a good plac [Re: gygeneral] #82914
07/03/08 01:13 PM
07/03/08 01:13 PM
Hudson Valley
conv440 Offline
conv440  Offline
Hudson Valley
That's where mine's hiding.
Re: hiding electronic ignition box ,where's a good plac [Re: hulmule] #82915
07/03/08 01:51 PM
07/03/08 01:51 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
That's where mine was in my C500 until I put the dual-point back in......
Troy
Houston Mopar Connection Club
Re: hiding electronic ignition box ,where's a good plac [Re: Barnabas_Kriss] #82916
07/04/08 03:26 PM
07/04/08 03:26 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Here's one on a B-body. Under the battery tray is where our shop normally mounts them to be out of view.
www.clarkclassic.com
Re: hiding electronic ignition box ,where's a good plac [Re: 375inStroke] #82917
07/05/08 12:16 AM
07/05/08 12:16 AM
Actually the Mopar installation instruction sheet specifically states that extending the wires to the box is not a problem.
