hiding electronic ignition box ,where's a good place??
#82903
07/01/08 10:13 PM
07/01/08 10:13 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
instead of running dual points in my AAR ,i'm going with electronic. where's there a good place to hide the box? or is a big deal and mount it on the fire wall?? thought it would look better hiding it some where easy?? thanks
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: hiding electronic ignition box ,where's a good plac
[Re: Barnabas_Kriss]
#82906
07/02/08 07:44 AM
07/02/08 07:44 AM
hulmule
northeast ohio
sounds like the battery tray to me!! just need to extend the wires.!!thanks guys
Re: hiding electronic ignition box ,where's a good place??
[Re: anlauto]
#82912
07/03/08 08:31 AM
07/03/08 08:31 AM
Posts: 542 Buckle of corn belt ,c. lll.
420SIX
I like putting them inside the car then run the wires back through the firewall
I put my rev limiter on top of heater box. Ran power from fuse block, and an unused terminal in bulk head connector for the engine wire
[Re: gtx6970]
#82913
07/03/08 10:10 AM
07/03/08 10:10 AM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
Remember, adding length to the wiring harness will eventually degrade the circuit . It was orginally designed to operate at a certain length wiring harness and extending this length changes the pattern if observed on a lab scope
I find that hard to believe. At 6000 RPM on an 8 cyl. motor, that's only 48kHz. A few straight feet of wire isn't going to do s#!t.
[Re: gygeneral]
#82914
07/03/08 01:13 PM
07/03/08 01:13 PM
Posts: 350 Hudson Valley
conv440
Hudson Valley
I put mine in the cavity behind the right front headlight and in front of the rad support. I just had my engine wiring harness made so the wire just extends beyond the washer pump down under the frame rail and into the cavity behind the headlight.
That's where mine's hiding.
[Re: hulmule]
#82915
07/03/08 01:51 PM
07/03/08 01:51 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
That's where mine was in my C500 until I put the dual-point back in......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
#82916
07/04/08 03:26 PM
07/04/08 03:26 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
I put mine under the battery tray. This way no need to drill any holes in the body and the box is readily accessible. I extended the wiring and wrapped it toghether with the existing harness. Works perfect.
Here's one on a B-body. Under the battery tray is where our shop normally mounts them to be out of view.
www.clarkclassic.com
[Re: 375inStroke]
#82917
07/05/08 12:16 AM
07/05/08 12:16 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
Actually the Mopar installation instruction sheet specifically states that extending the wires to the box is not a problem.
