Re: Any good Oil now that zinc is gone?
[Re: HEMIFRED]
#829068
10/13/10 08:05 PM
10/13/10 08:05 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Even Shell Rotella 15-40 has reduced zinc now. you can thank the catalytic converters on deisels for that one.
Valvoline VR1 20W50 Racing is reduced zinc.
You need Valvoline NFS(not for street use) oil it is listed in Jegs but can be ordered a lot cheaper at NAPA. I run crude base NFS Valvoline 10W30 racing oil.
[Re: 340SIX]
#829071
10/13/10 08:39 PM
10/13/10 08:39 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Thanks guys I knew the race forum guys would know what options are out there No matter what good oil cost it is worth it compaired to what it would cost if an engine is toasted
if your willing to spend the money, i would go with Brad Penn!
[Re: HEMIDARTS]
#829073
10/13/10 08:42 PM
10/13/10 08:42 PM
Posts: 603 Central Oregon
Rodney
Central Oregon
Brad Penn makes good oil with zinc.
I just bought some valvaline racing oil, im pretty sure it has zinc also.
Valvoline racing with VR1
[Re: johnscudashop]
#829075
10/13/10 09:13 PM
10/13/10 09:13 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I will post my standard reply once more.In over 40 years of racing I have never seen an engine failure due to the brand or blend of it's oil used. It's demise always comes from poor assembly, incorrect or inferior parts. SHOW ME ONE THAT DIED WHEN USING CORRECT WEIGHT, CLEAN OIL ,GOOD FILTER AND NORMAL RACE ABUSE
home of the Sox and Martin Hemi Duster
[Re: Barnstorm]
#829077
10/13/10 09:30 PM
10/13/10 09:30 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Pennzoil 25/50 RACING oil. If you are not comfortable with the zinc content in it,,add a bottle of Erson's zinc additive. I have had no problems there.
If you like drag racing, support your local track.
[Re: CHAPPER]
#829078
10/13/10 09:48 PM
10/13/10 09:48 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Anybody had any oil failures directly due to lack of zinc? Is this another Freon scare?
The little old lady from Pasadena is back!
[Re: 340SIX]
#829082
10/14/10 09:43 AM
10/14/10 09:43 AM
Posts: 36 SW Ohio
Flammopar
SW Ohio
Zalt ... It is formulted for older engines. You dont need any additives with this oil. Its the only oil I use in my 65 now.
Up in Flames Racing
[Re: Barnstorm]
#829083
10/14/10 10:22 AM
10/14/10 10:22 AM
Posts: 16,930 NC
440Jim
NC
My street driven 440 had a hydraulic cam that wiped a lobe/lifter after several years of running. Right after the year the oils reduced their zinc content.
IMO, only flat tappet cams are at risk. I think the rest of the motor doesn't need all the anti scuff protection.
