I pulled a couple of carbs off a hemi motor and want to ID them. One has a painted tag that reads 4971S 2975 40 and has a side stamping of 1866 and a top stamping of 1943.
The other has no tag and has a side stamping of 1862 and a top stamping of 2312.
Any other numbers I should be looking for? Here are the top view of the two carbs, the 4971S first:
The motor supposedly came out of a 1968 hemi charger, but the block I think dated 1966. The carb cleaner base was hacked up on one hole so I think maybe the un-tagged carb was meant for something else as the top is bigger.
Who knows where these carbs are from, what year, if they are desired for restoration work, etc.
I bet someone here knows! Thanks
