Brake Pedal loose play #828245
10/12/10 03:30 PM
10/12/10 03:30 PM
New Brunswick
U
Unfair Advantage Offline OP
U
New Brunswick
when in rest position, I can lift my brake pedal up about one inch. (Auto trans, manual drum)
The brakes stop the car fine, but the brake light switch is on all the time because the pedal rests too low and the light switch thinks i have the pedal pushed, which is false.
I dont see any kind of return spring, and the lights never stuck on like that before, untill i changed the shoes and bled the lines.
WHAT DID I DO?
Re: Brake Pedal loose play [Re: Unfair Advantage] #828246
10/12/10 04:00 PM
10/12/10 04:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need to adjust the brakes up tighter.
