Brake Booster Install - Didn't Fit #828059
10/12/10 10:27 AM
10/12/10 10:27 AM
Bethlehem, PA
Beemeister Offline OP
Bethlehem, PA
Si I got this booster from Advance, I knew it wasn't the correct Bendix, but it said "fit and function" is the same. First problem was fitting to the metal brake plat. The booster stud pattern is OK, but the pushrod is not exactly centered to the hole in the plate. A little egging of the plate holes fixed that. Unfortunately, the firewall is the same and I'm not cutting the firewall to fit this thing. BTW it's huge. It may be OK on a 318, but on a 440 its very close to the valve covers, if it would fit.
What is this booster from anyway? I guess its gotta go back and start the crapshoot to see if I'll eventually get a correct Bendix.
How much clearance does the Bendix have with a 440? Anyone else have a similar experience or solution?
'70 Coronet 500. Now 440/727. AC/ps/pb
Re: Brake Booster Install - Didn't Fit [Re: Beemeister] #828060
10/12/10 01:13 PM
10/12/10 01:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looks like a mid 80's Dodge truck application....
Re: Brake Booster Install - Didn't Fit [Re: DAYCLONA] #828061
10/12/10 01:32 PM
10/12/10 01:32 PM
Bethlehem, PA
Bethlehem, PA
Here's another pic.
I just returned it, and of course that was the only one available, so looks like I'm outta luck.
Re: Brake Booster Install - Didn't Fit [Re: Beemeister] #828062
10/12/10 01:46 PM
10/12/10 01:46 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
What are you trying to fit it on?
Re: Brake Booster Install - Didn't Fit [Re: Beemeister] #828063
10/12/10 02:09 PM
10/12/10 02:09 PM
Bethlehem, PA
Bethlehem, PA
Ooops, sorry. Its for a 1970 Coronet. I was looking to switch out the power drum booster for the power disc one.
Re: Brake Booster Install - Didn't Fit [Re: Beemeister] #828064
10/12/10 02:28 PM
10/12/10 02:28 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
There's a difference? I know the MC is different but the booster?
Re: Brake Booster Install - Didn't Fit [Re: Jwilli500] #828065
10/12/10 02:33 PM
10/12/10 02:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Drum brake booster (Midland Ross)
Re: Brake Booster Install - Didn't Fit [Re: 1_WILD_RT] #828066
10/12/10 02:35 PM
10/12/10 02:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Disc brake booster (Bendix)
Re: Brake Booster Install - Didn't Fit [Re: 1_WILD_RT] #828067
10/12/10 03:03 PM
10/12/10 03:03 PM
Bethlehem, PA
Bethlehem, PA
I ordered the Bendix for discs, and this unknown thing showed up, so the rebuilder must have put the wrong booster in the box. There are no other same part numbers in the rebuilder inventory, so I will have to use the Midland for now and seek out a Bendix somewhere else.
