100 amps is never overkill... total output is not send if demand is not required.
you can get a a milliom amps alt but if car demand requires just 60, alt will send 60
the advantage of a 100 amps alt is you'll get allways the juice to the car from alt instead from batt and most important AT IDDLE.
save the right load at iddle and you are SET
my advice... get a 100 AMPS ALT... or 78 amps alt if wanna stock piece ( lates 70s mopar cars )
http://www.moparmusclemagazine.com/techa...ator/index.html60 amps alt is great improvement too
you can drive these high output alts on stock wiring if you don't have accesories and if you have a healthy wiring, although some small and easy upgrade will be nice too
