383 Head Question
#82788
07/01/08 05:33 PM
07/01/08 05:33 PM
Posts: 1,032 Ohio
dobie
Ohio
Does anyone know what part number heads should be on an original 383 2 bbl engine? I'd like to swap cams at some point, but I would think I should do some work on the heads. I'd assume that the stock heads aren't the best for a larger cam, as the motor is a low compression 383. Would you guys recommend using "906" heads instead of the stock 2bbl heads? I have a set laying around on a blown motor. If the top end on that motor is good, I suppose I should use those heads. Thanks.
1968 Plymouth Road Runner
383 4 speed
Re: 383 Head Question
[Re: rrunner]
#82790
07/01/08 10:16 PM
07/01/08 10:16 PM
Posts: 1,032 Ohio
dobie
Ohio
Yes, 1968. That's interesting. I would've thought that the low compression motors would have had different heads compared to the HP motors.
383 4 speed
[Re: dobie]
#82792
07/01/08 10:42 PM
07/01/08 10:42 PM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
the only difference between HP and non HP heads is the valve springs, same casting/valve size
[Re: 65rbdodge]
#82793
07/01/08 11:09 PM
07/01/08 11:09 PM
Posts: 1,032 Ohio
dobie
Ohio
I'd still be better off by doing some head though, compared to just swapping cams, right?
The cam I'm looking at is a Comp 21-223-4 I think. Is this too much for a stock 2bbl motor which now has a 4bbl setup?
383 4 speed
[Re: dobie]
#82794
07/02/08 12:26 AM
07/02/08 12:26 AM
DaytonaTurbo
Manitoba, Canada
Big blocks all ran the same heads. There were pretty much only a few substantial design differences between the different kinds of heads. 906's are no better than any other of the open chamber big block heads. Some would argue they are worse than the 70's heads because at least the 70's heads came with hardened valve seats. Doing head work or picking up a set of aftermarket heads is always a good idea. Flow is flow, so better flowing heads will make more power with a given cam. Quote:
That cam is the XE268H. Don't call it the 21-223-4, most people don't know off hand what what means, but the letter/number cam grind designation for comp's line of cams is much more familiar to most than the part #.
268H is about the most cam I would want to run in a street 383. It'll be a great street/strip cam with a lopey idle. Do a search, some member posted a vid of his 383 with the XE268H a while back. If it's the 4sp car in your sig that this motor is in, and you have 3.55 or numerically higher rear end gears, IMO this will be a good cam for you.
[Re: DaytonaTurbo]
#82795
07/02/08 08:58 AM
07/02/08 08:58 AM
Posts: 1,032 Ohio
dobie
Ohio
Thanks for the information. Yes, it's the same car. It's a 4 speed with 3.91 gears. Thanks again.
383 4 speed
[Re: JohnRR]
#82797
07/02/08 10:45 AM
07/02/08 10:45 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
As said, Ma Mopar used the same heads with the 2bbl & 4bbl cars. However, It's really hard to make compression in a 383 with open chamber heads. If you're willing to spend the money on rebuilding a set of heads, I'd go find myself a set of 516's (closed chamber), then spend the extra money to cut in a set 1.74 exhaust valves. You'd then have a decent set of heads that would probably get you to somewhere around 9.25:1 compression with your existing bottom end. Use .020 shim style head gaskets when you re-assemble. You're going to need compression to be able to realize the potential of the larger cam.
[Re: StealthWedge67]
#82798
07/02/08 03:44 PM
07/02/08 03:44 PM
Posts: 1,032 Ohio
dobie
Ohio
Many thanks again for the information. Maybe I'll get lucky and find a set of 915's or 516's at Carlisle for cheap.
383 4 speed
[Re: dobie]
#82799
07/02/08 04:40 PM
07/02/08 04:40 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
516's , most likely ... 915's , only if you are there on vendor setup day and only if the person is uninformed
[Re: JohnRR]
#82800
07/02/08 04:55 PM
07/02/08 04:55 PM
Posts: 1,032 Ohio
dobie
Ohio
Well, I guess I'll look around for the 516's then. What would a fair price be? I'm clueless here on this one.
Thanks.
383 4 speed
[Re: JohnRR]
#82802
07/02/08 05:48 PM
07/02/08 05:48 PM
Posts: 1,032 Ohio
dobie
Ohio
That sounds good in theory. Somehow I doubt though that I'd find a set that cheap.
383 4 speed
