Re: 605 Hemi
[Re: Big B]
#827452
10/11/10 06:49 PM
10/11/10 06:49 PM
Posts: 12,401 Taxes & Virus's R-US, NY
Dragula
What are your goals and its intended usage? Kinda left that wide open. I run a 484 efi Hemi, why efi, why a Hemi?
For all out competition while still using a mopar, the Predator, or Stage V Millenium hemi heads will make a lot more power than what I have...All in all, its still cheaper to build a cheppy, but it is what it is.
Re: 605 Hemi
[Re: Big B]
#827457
10/11/10 08:11 PM
10/11/10 08:11 PM
Quicktree
My intended usage is in a 69 Sport Satellite. I want a car that will run 9's easy and still be able to cruise at 70mph around 15-1600rpm. Hydraulic roller cam and maintenance free. All I want to do is change oil! Looking to make around 1200hp on pump gas. No super chargers or turbos. EFI because I am sick of carburetors!
good luck
Re: 605 Hemi
[Re: Big B]
#827461
10/11/10 08:37 PM
10/11/10 08:37 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
What's so funny? If you gear a car down to run 1500 rpm at 70mph down the highway, it takes a lot of power to do that and run 9's. My car runs low 10's right now at 750hp, but spins 3500rpm at 70 mph.
you might also consider a Gear Vendors overdrive. Eddie(elvis) says he loves his and now uses it in the 1/4 mile too.(running 8s)
Re: 605 Hemi
[Re: Big B]
#827463
10/11/10 09:02 PM
10/11/10 09:02 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
1200 HP on pump gas and low maintenance? I dont see you doing that with a N/A Mopar engine without the use of a turbo or supercharger.
LBSR
Re: 605 Hemi
[Re: Big B]
#827468
10/11/10 11:41 PM
10/11/10 11:41 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I wish someone would make a 6 speed transmission that can handle tons of power, and still give good highway cruise. GV is a start, but I wish they had 2 over drives instead of just 1. Like a .6 or so.
I don't know if it is on the TCI website yet, but they have a 6 speed automatic, with paddle shift and an electronically controlled multi stall converter. This is all new stuff, and the engineer I know @ TCI said the Pro Stockers were going to try it also.
It is based off the 4L80E GM transmission. I think he said they were $4,000.00..
Chris..
Re: 605 Hemi
[Re: HEMIFRED]
#827470
10/12/10 07:48 AM
10/12/10 07:48 AM
Dragula
Predator Engine 1150hp prices starting at 23k http://www.musclemotorsracing.com/engines/top-krate.htmlThe heart of any internal combustion engine are the cylinder heads. We use THE BEST flowing cylinder heads for big block Mopars, the Predator cylinder head (by Indy). This head features symmetrical intake and exhaust ports (IE: Pro Stock) capable of flowing over 540 CFM when we CNC port them. We actually have 2 proprietary intake port programs. The standard port utilizes a 2.400 intake and 1.850 exhaust valve sizes. The large CNC port program uses a 2.450 intake valve (titanium required). The small intake runner measures 440 cc’s, the large port measures 480 cc’s. The valves are actuated by T&D rocker arms that are available in 1.75, 1.80 and 1.90 rocker ratios. These rocker arms have no offset which makes them very stable at high engine speeds. We have raced them for years on engines with valve springs that have 450 psi seat pressure, over .950 cam lift and turning over 8500’s with no failures! The rest of the valvetrain(retainers, locks, springs, spring cups, cam and lifters) are supplied by Comp Cams. These are all bulletproof components that ensure durability that wins races!! Our standard Top Krate comes with a 1x4 cast intake manifold (2x4 optional) and sheet metal valve covers. Performance: Our single 4bbl Top Krate makes 1150 HP @7400 and 900 ft lbs @ 5700. This should propel any 1850 lb dragster to 6.90’s-7.0 range on motor in decent air. Add a single stage and 6.50’s are no problem! A 2350 lbs. door car should run 7.40’s-7.50’s all motor and 6.90’s on a single stage. All of this performance can be had (intake to oil pan) for $22,999
