Where can I get a 31 tooth speedometer gear? #827423
10/11/10 04:38 PM
10/11/10 04:38 PM
United States
STLDuster Offline OP
United States
I am running a 3.23 gear a 28" tire (275/60 R15). From what I can tell I need a 31 tooth speedometer gear (Part # 52068153). I looked at yearone and they skipped over the 31 tooth (unless I overlooked it). I called my dealer, they said they had been discontinued and that no one in the country has them in stock.
I want to double check and make sure I am looking for the right gear and ask if anyone knows where I can get a hold of one?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Where can I get a 31 tooth speedometer gear? [Re: STLDuster] #827424
10/11/10 04:49 PM
10/11/10 04:49 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
31 is correct. Here is the only good used one I have available. http://www.brewersperformance.com/proddetail.asp?prod=SP31U
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Where can I get a 31 tooth speedometer gear? [Re: STLDuster] #827425
10/11/10 04:56 PM
10/11/10 04:56 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
ebay
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Where can I get a 31 tooth speedometer gear? [Re: 471Magnum] #827426
10/11/10 05:17 PM
10/11/10 05:17 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
I have two 31 tooth speedo pinions in stock on the shelf and ready to ship, part# FD031, $92.00 each.
Re: Where can I get a 31 tooth speedometer gear? [Re: rick@laysons] #827427
10/11/10 09:27 PM
10/11/10 09:27 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Where can I get a 31 tooth speedometer gear? [Re: 340SHORTY] #827428
10/11/10 09:31 PM
10/11/10 09:31 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Good grief, I just sold one for $20 including shipping.
Re: Where can I get a 31 tooth speedometer gear? [Re: STLDuster] #827429
10/11/10 09:31 PM
10/11/10 09:31 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
There are 4 on the bag for 39.00 each.
Re: Where can I get a 31 tooth speedometer gear? [Re: 340SHORTY] #827430
10/11/10 10:20 PM
10/11/10 10:20 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Last one I got was ten bucks.
Re: Where can I get a 31 tooth speedometer gear? [Re: DAMOPARS] #827431
10/11/10 11:22 PM
10/11/10 11:22 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
$30.00 one on ebay?
Re: Where can I get a 31 tooth speedometer gear? [Re: Mr_fixit] #827432
10/11/10 11:26 PM
10/11/10 11:26 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Are they the same for a 904 and a 727? I just switched out my rear and my speedo is off...
The Blue Goose
My instagram: Bossride
Re: Where can I get a 31 tooth speedometer gear? [Re: BossRide] #827433
10/12/10 03:29 AM
10/12/10 03:29 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
yes
I am truckless..
Re: Where can I get a 31 tooth speedometer gear? [Re: STLDuster] #827434
10/12/10 09:50 AM
10/12/10 09:50 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
You have a PM...
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Where can I get a 31 tooth speedometer gear? [Re: rick@laysons] #827435
10/12/10 12:38 PM
10/12/10 12:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rick, have you found the exit yet?
- Stu Harmon
