Cracked block??
#827400
10/11/10 03:45 PM
10/11/10 03:45 PM
Posts: 14 san diego
clownin mopar
san diego
I hope someone here can help me answer a question. After many years, I'm getting back into cars and have been offered a HEMI block for my project. It has a crack in the middle main web about 3" long. I have checked into some metal shops that weld professionally and can do cast iron (pre heat, weld, cool down etc.). My question is, has anyone done this, and would it even hold in this high stress area? The horsepower levels would be under 500. Thanks, Henry
If I knew retirement was this great, I would have done it first!
Re: Cracked block??
[Re: clownin mopar]
#827402
10/11/10 08:58 PM
10/11/10 08:58 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
It would not be a good purchase. My
RIP Monte Smith
Re: Cracked block??
[Re: tubtar]
#827406
10/12/10 01:23 AM
10/12/10 01:23 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree with all of the above.....Make a great door stop. If you want to chance it get ahold of Mike at www.rocketresto.com, he tells me there's a guy he knows in Western Washington who's a magician with cast iron welding. Personally I don't have allot of faith in any type of cast iron welding in a main web area.
Re: Cracked block??
[Re: rbds65]
#827407
10/12/10 04:26 AM
10/12/10 04:26 AM
Posts: 660 San Diego
formula S
San Diego
You may want to check out a company called Lock-N-Stitch, the kits are reasonable, or diesel shops do it for you. Cummins diesels are fixed this way a lot. I am not recommending or condemning, just making you aware of another method to fix a crack in cast iron. rbd
