68 RR from auto to 4 speed #827051
10/11/10 12:15 AM
10/11/10 12:15 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Does anyone know the part number for the pilot bushing to use when you have a engine that was for an automatic trans. I am putting a stock 4 speed trans in the car. The engine is out of a 69 charger 383, I am putting it in our 68 RR with the orginal 4 speed.The parts stores in town don't seem to get it.
Thanks to all
Re: 68 RR from auto to 4 speed [Re: rc68rr] #827052
10/11/10 05:50 PM
10/11/10 05:50 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Here is a tech article from bigblock dart it talks about the roller bearing for the auto convertor hub in the cranks not drilled for 4 speeds. I believe you will have to shorten your input shaft if the crank has not been drilled for the 4 speed. The bearing number in the article is BCA # FC69907. Here is a link to the article http://www.bigblockdart.com/techpages/4sptech.shtml
Hope this helps you , Matt
Re: 68 RR from auto to 4 speed [Re: mattsmopars] #827053
10/11/10 11:30 PM
10/11/10 11:30 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Thanks Matt
Re: 68 RR from auto to 4 speed [Re: rc68rr] #827054
10/12/10 10:22 PM
10/12/10 10:22 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
Both, Dorman and the Napa stores used to make a 5 thousands undersized bushing. The cranks are usually drilled, just not finished and these will usually do the trick. Don't cut the input shaft if you don't have to.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
