Re: What are these parts? [Re: OzHemi] #827031
10/11/10 12:12 PM
10/11/10 12:12 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: What are these parts? [Re: OzHemi] #827032
10/11/10 01:05 PM
10/11/10 01:05 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
a helper pump to get the gas from the tank to the next county where the engine is is at!
Re: What are these parts? [Re: enelson] #827033
10/11/10 01:35 PM
10/11/10 01:35 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...The Car with 2 zip codes. You can jump in & go visit your relatives & back & use no gas. Cool
Re: What are these parts? [Re: thehemikid] #827034
10/11/10 04:05 PM
10/11/10 04:05 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Yes indeed, it is a lift pump, usually for diesel. It is still on the spec for a NYC garbage truck, and it's plumbed with tees and checks to be used as a helper via switch on the dash. The end cap comes off to reveal a screen.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: What are these parts? [Re: WayneM] #827035
10/11/10 04:57 PM
10/11/10 04:57 PM
scratchnfotraction Offline
looks just like the elect fuel pump from my 85 nisson king cab
yes it comes off for a filter
the relay looking thing looks like the relay under the dash that turned the pump on as long as it had oil pressure IIRC
looks like it might have been for primming the barge after it had been in dry dock for a while
should be a higher pressure than most other banger pumps like it
Re: What are these parts? [Re: OzHemi] #827036
10/11/10 10:56 PM
10/11/10 10:56 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
A lot of the "land yachts" of that era used this type of pump to stay "afloat". The output was plumbed into an unused vent fitting on top of the yachts fuel tank. A long hose was fitted to the suction side, which was inserted into other vehicles fuel tanks. The pump was then activated till the yachts tank was full, or the object car was empty and another car was located. The only economical way to keep the massive barges afloat.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
