Re: Anyone Used Holley's Rebuild Service?
[Re: hemigod426]
#826943
10/11/10 10:20 AM
10/11/10 10:20 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
From the ones I have seen in person at least their replating does not look original at all. More like they had them bronzed. Or at least yellowish bronzed. Should be more like a goldish green, which is hard to describe.
The pics on Harms page look pretty good, but I have not seen his work in person. If you are Want a show quality original job, and want a second opinion call The Old Carb Doctor (828) 659-1428 and see who he recommends. He knows most people in the antique carb biz, but he doesn't do Holleys or modified hipo stuff , I'm sure he could point you in the right direction.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: ademon]
#826945
10/11/10 11:41 AM
10/11/10 11:41 AM
Posts: 3,821 New State
kidmopar
New State
I read a post on this a while back saying that there work is spotty at best. try calling Scott heres the link : http://www.harmsauto.com
"The Best!" Call Scott
[Re: RoadRunnerJD]
#826946
10/11/10 12:36 PM
10/11/10 12:36 PM
Posts: 1,060 Ball Ground GA
TrueTripleX
Ball Ground GA
I don't know that Holley does them anymore? It sounds like all you need is a simple rebuild if they are "cosmetically" OK or do you want them concours restored? Why not just buy the gasket kits and do them yourself? Holley's are pretty easy. There are a few people on the Forum who can help. Just ask who else other than Holley dies them.
I have used both Scott and Holley. In the last year I have had 2 sets of Hemi carbs and 2 sets of 6 paks done by both. After comparing the two, I will recommend Scott. Holley does a good job, BUT IMO Scott is much better at authentic RESTORATION, and his carbs just plain run better out of the box. Don't get me wrong because Holley DOES do a good job, but Scott is better
