the time has come big block help
#826762
10/10/10 08:31 PM
10/10/10 08:31 PM
Posts: 2,449 nc
earthmover
nc
well guys a while back picked up a 72 dart for my son to build up a new project and he wants big block power ...so now i need some good help from you guys to point me in the right way.. the base of the build will be a 400 stroked to ????????? what ever is the best combo.. ive been thinking of some parts but would like to here some from the pro.. thought about some indy 440-1 vic cnc ported or some b1 dont know alot about the offset rocker stuff so any info ... we would like to run the car down in the 6.50 to 6.00 index 1/8 mile car is a 72 dart that will be ladder bars and mini tube for larger tires and full cge with glass hood and bumpers and maybe fenders.... so lets here it guys need to start looking for parts oh and it will be full roller.
Re: the time has come big block help
[Re: earthmover]
#826763
10/10/10 09:15 PM
10/10/10 09:15 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You dont need any of those cylinder heads to run 6.50's- 6.00s. A set of good SR's, max wedge will get you there and save dough on the rocker gear that way. EZ's as well.
You cant go wrong with any of the 400 based builds, be it a 451, 470 or 499. All depends on car weight and what your willing to compromise here and there, as far as parts longevity and engine lifespan and rpms are concerned. Obviously budget as well, but you dont need the heads you mentioned in my opinion.
RIP Monte Smith
[Re: earthmover]
#826768
10/12/10 02:39 PM
10/12/10 02:39 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My combo; 400 block .030 off-set ground 413 crank to 3.900 strok eagle 6.385 chevy rods isky solid roller cam w/.680-.660 lift and 275-280 dur. @.050 home ported rpm`s victor intake w/adapter for 1050 dommy 2" super comp hookers and 3 1/2" ex. into bullet muffs hoosier 29x13.5 hoosier qtp`s on 12" weld drag stars 8 3/4 rear w/4.11`s, spool and dtchman 30 spline axles 727 w/an 8" 5000+ continental vert car weights 3150 w/me ready to race.........hope this helps and good luck.
[Re: earthmover]
#826772
10/12/10 04:19 PM
10/12/10 04:19 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I have on suggestion. Buy the 440-1 kit right off the bat. You get everything including intake so your off to the rodeo and will make tons of HP as shipped with potential for more if you have them CNC'd later like Moderns Xmas special. I bought SR's and then opened intakes to max wedge got the Indy intake, had to get a vally plate?? bought 4 different sets of rockers so far. welded to make 440-1' out of them and I still don't have the valve covers To do it again I would go 440-1 right off the bat. or get edelbrocks and home port them??
