Re: How to make Challenger hook?
[Re: joshking440]
#826682
10/10/10 07:51 PM
10/10/10 07:51 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
I'll say it again....... 90% OF MAKING ONE HOOK IS IN THE FRONT END.........and you never mentioned one thing about your front end........ What do you have and how's it set up? BTW.........125 is enough to run 10.50's.......and when you finally get it To 60 foot good, it'll pick up at least 2MPH, so it'll run at least 127, which is enough to run 10.30's.......
If you can't handle the truth, you're living a lie.......
[Re: ToddP]
#826684
10/10/10 08:17 PM
10/10/10 08:17 PM
Big Squeeze
Oologah, Oklahoma
The front end has 5" of travel. 318 torsion bars. calvert 90/10 shocks Bondo Bob upper arms with heim joints and afco ball joints
i can eaisly jounce front end by hand.
with the shocks on the rear suspension it is very stiff and appears not to move at all. with the rear shocks removed i can jounce it by hand.
What lower control arm bushings? Heim joint strut rods? or does it have rubber or poly bushings at the front of the strut rods?
Does the car still sit like this?
If so, it appears to sit a little high in the rear for instant, right at the hit, weight transfer IMHO......Ideally the rear would be down farther so it's sits basically level.......
I've had the best luck with drag radials by stalling the car up to about 3,500, then let off the brake, and as soon as you can feel the car even move one inch, you can mat it........I've got a car that runs 10.90's @ 122 like that.......If I just floor it right off the bat, it blows the tires off...... but, the car has 17" Drag Radials and sits pretty low, so the Center of Gravity is pretty low.......
On drag radials, an EXTREMELY loose front end combined with a CG as high as you can stand is the key.........
[Re: ToddP]
#826689
10/10/10 08:57 PM
10/10/10 08:57 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
I think you said that when the shocks are full soft the rear of the car will bounce freely....Right.... IF so your spring is fine. When I had cal tracs on my challenger I set the bars just touching with me in the car.
[Re: ToddP]
#826691
10/10/10 09:20 PM
10/10/10 09:20 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Why I loved my homemade traction bars!Old napa shocks...90/10 in front Same tires as you 1.30 60's 5.60's in the 1/8th Fixing to see if she'll hold a few extra hundred hp! Sometimes simplicity is the easiest!
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
