O.E. Hemi 2x4 intake, flow improvements?
#826395
10/10/10 04:27 PM
10/10/10 04:27 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
I have a 528 Hemi with cnc ported MP alum heads by MCH. I ran the MP repro crossram with the correct 770 Holleys. I kept having intake sealing problems and idle issues and just got tired of trying to make it work and sold it and bought the Mancini kit w factory 2x4 intake with Edelbrock 625 cfm AFB's. The idle quality and overall driveability on the street improved by about 200% and this is a street/strip car that is 90% street. The down side is that it feels about 50 horses light, it really went down noticibly above 4500 rpm. One thing I know is that the head ports are about a 1/4 " bigger than the intake, port matching is in order. Plenum mods, porting, 750's instead of the 625's? I will be transplanting this engine into my wifes cuda w/Shaker hood, so will be sticking to this intake. Any suggestions appreciated.
Re: O.E. Hemi 2x4 intake, flow improvements?
[Re: JohnRR]
#826398
10/10/10 06:32 PM
10/10/10 06:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Lee you can run the Stage 5 intake under a shaker and I am pretty sure there is a shaker adaptor for this set up. the stage 5 will get you back the 50HP
I had a Cuda(the LSD Cuda) at the shop that ran the stage V intake. We had a custom base made up and everything fit nicely. Looked great. I did have to do some creative work on the fuel lines, but it wasn't any big deal.
While I never dynoed it, I bet it's worth a significant amount over the stocker. Mods to the stock intake usually incorporate a Vanke mod that is taken to the next level.
MB
[Re: Lee446]
#826403
10/11/10 02:16 PM
10/11/10 02:16 PM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
Lee, We have a cnc program for this intake and a dam that we install. This has yeilded excellant resusults in the street Hemis we build. Larry
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
