Re: Please Look At My Dyno Sheet
[Re: JohnRR]
#826279
10/12/10 12:46 PM
10/12/10 12:46 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That's what I see too. Take some of that pump shot out and watch the lean out on the top end.
What intake is on the engine?
Engine dyno or chassis dyno?
[Re: Moparmal]
#826283
10/13/10 07:59 AM
10/13/10 07:59 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What's the advertized RPM range of that cam? it drops off at 5800 for sure, is that the cam's design? or are you getting valve float or ignition problems preventing you from turning more RPM?
FWIW, my comp XE275HL is similar to your specs... I've got .525 lift, 235 degrees at .050" and mine starts to die after 5800 as well. but then again, they advertize a power band of 1800-5800 rpm.
**Photobucket sucks**
[Re: BradH]
#826288
10/15/10 07:18 AM
10/15/10 07:18 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Jeff you took it to the wrong dyno(LOL) Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#826289
10/15/10 09:42 AM
10/15/10 09:42 AM
Posts: 4,799 ILL
MLR426
ILL
The XE extreme energy comp cams have an aggressive lobe design and need extra seat pressure and open load pressures to sustain high rpms. Even though a cam may be design to make power up to a certian rpm the engine make up will determine it's over all out put. Valve train weight etc plays a roll as well, thus the extra spring load to go along with the aggressive lobe design.
logan426
[Re: JAKE68]
#826290
10/15/10 10:03 PM
10/15/10 10:03 PM
Posts: 121 Michigan
dusterjp
Jake, I will stop by your shop in a few days. I would like your opinion.
