Stupid & basic small block motor mount question... #826108
10/10/10 11:35 AM
10/10/10 11:35 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I'm having a brain fart - but what side of ears do the motor mount saddles mount to? the front of the ears or the back side?
I have them on the back side right now but my z-bar alignment isn't as good as I think it should be and I had to "stretch" my trans mount to fit so I think the engine needs to come back- but all the pics I can find show everbody else running them this way.
Re: Stupid & basic small block motor mount question... [Re: 72demon416] #826109
10/10/10 11:50 AM
10/10/10 11:50 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
rear
Re: Stupid & basic small block motor mount question... [Re: Dons Dart] #826110
10/10/10 12:18 PM
10/10/10 12:18 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
rear
From a previous post (and from which I will now never forget):
The mounts should be like a woman's legs. Behind the ears.
You know who you are.
Re: Stupid & basic small block motor mount question... [Re: Commando1] #826111
10/10/10 01:22 PM
10/10/10 01:22 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
rear
thanks thats a good way to be able to remember stuft like this
Re: Stupid & basic small block motor mount question... [Re: 1Fast340] #826112
10/10/10 01:59 PM
10/10/10 01:59 PM
Well on a related note I remember which wire is the hot (input) one at the brake pedal sw (you have white and pink) by thinking "hot pink" but that's not (near) as good as the one above
Re: Stupid & basic small block motor mount question... [Re: Commando1] #826113
10/10/10 06:49 PM
10/10/10 06:49 PM
Sask, Can.
Sask, Can.
It's not the answer that I had hoped to hear but what I was expecting. Thanks guys
Re: Stupid & basic small block motor mount question... [Re: 72demon416] #826114
10/10/10 08:16 PM
10/10/10 08:16 PM
w the mts on the correct side any idea what part is wrong (or mounted wrong)? Shouldn't have to (nor would you want to) stretch the trans mount
Re: Stupid & basic small block motor mount question... [Re: RapidRobert] #826115
10/10/10 08:25 PM
10/10/10 08:25 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
mountingbolt holes on the transmissionmounts flat part that bolts up to the transmission are usualy alitle oval to be adjustable
Re: Stupid & basic small block motor mount question... [Re: 1Fast340] #826116
10/10/10 08:53 PM
10/10/10 08:53 PM
yes but I gathered that he used up the slot travel & needed more. Maybe crossmember reversed (if the mounting holes are symmetrical but the trans mount inside it is offset) or wrong trans mount or ??
