Dakota A/C problems.........
#82597
07/01/08 11:17 AM
07/01/08 11:17 AM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
The a/c quit working on my 2000 R/T. The guy who tried to recharge it says that the cartridge with the orifice in it is blown out. Does that part exist and is it replaceable? Thanks!
Re: Dakota A/C problems.........
[Re: slantzilla]
#82598
07/01/08 11:19 AM
07/01/08 11:19 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks!
the whosit whatsit??? is that like the harmonic muffler bearing?
[Re: slantzilla]
#82603
07/02/08 02:57 AM
07/02/08 02:57 AM
Posts: 720 Texas
jetdoctor_75402
super gas
super gas
Texas
The "The fixed orfice is located inside the metal portion of the condensor piping manifold on the passenger side at the front end of the rear half of the two piece liquid line (low side). (the part up front closer to the radiator). I replaced one about a year ago believe its on the "low pressure" side. Sometimes you can get the item to shake out, but most of the time you need use a special tool. you access it by seperating the two halfs of the liquid line and its inside. Not a job for a person who is not familiar with ac systems and what they can do to you or what you can do them.
Did your truck just quit cooling or did the blower fail, a little more detail would help.
regards,
doc
[Re: jetdoctor_75402]
#82604
07/02/08 01:18 PM
07/02/08 01:18 PM
slantzilla
Park Forest, IL
Truck was wrecked a couple years ago. Body shop replaced the condensor and radiator. System worked fine until this spring. It was low on refrigerant but the guy who was trying to charge it could not get it to make any pressure on the high side.
