TQ tuning issue using M1 intake (SB stroker) #825953
10/10/10 01:24 AM
10/10/10 01:24 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Anyone had problems running a TQ on a M1 SB ?
Specifically, the low speed / idle circuit runs waaaay lean , and no amount jetting up or rod changes has an effect.
Anyone got any solutions so I can keep using this carb?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825954
10/10/10 02:04 AM
10/10/10 02:04 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Are you checking your engines vacuum with a vacuum gauge? That's where I'd start. It's possible you have a leak somewhere.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ScottSmith_Harms] #825955
10/10/10 03:00 AM
10/10/10 03:00 AM
Moparmal Offline OP
Moparmal  Offline OP
SSH - I just swapped the M1 in -
I had a vac guage on it this morning - its reading around 13 at 900 rpm, but it does waiver a little beween 10 and 13.
I did the leak test with fluid around the intake flange but it had no effect....
As soon as you blip the throttle, and as the rpms come down, the Vac drops to almost zero and the engine flutters and almost dies.
Because its been so badly behaved at low speed, I assumed it was the low speed circuit -
(I checked all the carb gaskets and this carb ran 12.6 at the track last weekend on an LD340)
Are you saying that the TQ shouldn't be effected by the M1 this badly?
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825956
10/10/10 03:07 AM
10/10/10 03:07 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
is your M1 the spread bore? i'm running a t-quad on my warm 360 and have the pri jets drilled to .101 and have the piston set up at just one turn off bottom, make sure its bottomed and you note exactly when it starts to come up. also make sure you have the right piston spring on the rods, it should be about 1.5" tall and the spring dia should be .023. i have seen other springs that are not correct. i'm running without a choke and related hardware.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825957
10/10/10 03:12 AM
10/10/10 03:12 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i'm also running the older strip dominator intake with the plenum worked over, this is what the M1 was patterned off of.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825958
10/10/10 03:50 AM
10/10/10 03:50 AM
Moparmal Offline OP
Moparmal  Offline OP
ademon - in a round about way you've answered the problem.
I needed to know if these SP intakes caused issues with TQs - clearly as your running one on a non stock 360 , this tells me the TQ circuitry can work fine on an M1.
Obviously my problem is elsewhere - and I'm thinking SSH is right, and its a Vac leak.
I've had TQs a long time - there's no issue with the calibration - except that I knew something was up when I had to go so rich on the primaries and it still showed lean on the AF guage.
I just hope this intake is not porous - I bought it off a member here.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825959
10/10/10 03:56 AM
10/10/10 03:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Try using an unlit propane torch to detect vacuum leaks, if even a small amount of the gas finds it's way into the engine you should see an RPM increase. Works great and leaves no mess.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825960
10/10/10 04:01 AM
10/10/10 04:01 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
maybe the choke pulloff? but doubt it. try spraying around the intake to head and see what happens, maybe the intake was milled a bit, mine was loading up a bit and idling rough till i adjusted the piston/rod setup precisely. Not sure about idle circuit my engine is about 400hp and has run low 12's with a holley, Maybe someone that has run a t-quad would know what idle mods need to be done on a very hot big cam motor.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825961
10/10/10 04:08 AM
10/10/10 04:08 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks for the tips on leak checking - I reckon my workshop guy will be on to it.
ademon - My engine only makes 370 with the LD340 so its not crazy on the cam side.
Re the intake - it was new so its not milled.
This is why I find it so hard to believe its leaking - it was a flush fit using if Felpro gaskets.
What makes e think you're both right is that the AF gauge goes off the scale lean when I lift off.
Probably sucking air in no doubt.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825962
10/10/10 04:14 AM
10/10/10 04:14 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I do like to run the 1/4" spacer with the thin gaskets on each side and not the cheap looking thick ones that are sometimes in the kit.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825963
10/10/10 04:24 AM
10/10/10 04:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
BTW what size jets you running? do you still have the choke setup on it? hate to drill jets when i don't know where i'm at, an AF meter is a big help i need to get one.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825964
10/10/10 04:46 AM
10/10/10 04:46 AM
Moparmal Offline OP
Moparmal  Offline OP
@ ademon - I realised I had a problem when I went to .107th primaries and it showed lean at 16 AF on the AF guage at 2100 rpm in top gear.
Please note: Last weekend I ran 12.6 with the LD340 - AF guage read 12.5 at idle, 14-15 at cruise, 12.4 at WOT in 3rd.
When you see that the WB AF guage shows pretty accurate readings - I start to worry when I have 16s AF and I'm running .107 primaries with the tree on 5 turns (1996 rods too) !!!
The car drives like a pig as well -fluttering off idle and other issues.
To run it that rich and still show a lean - ish mixture - there's something not right.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825965
10/10/10 11:56 AM
10/10/10 11:56 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It is possible to be rich and show lean if the mix is not being ignited. The sensor reads the oxygen not the fuel and if the mix does not burn it will read that unburned oxygen as a lean condition.
I think it would be worthwhile to throw a set of new plugs in, mabey one got fouled out then you started throwing fuel at it to cure the lean condition and wreaked all kinds of havok on it.
The single plane intake will give less signal to the carb and require a touch more fuel. I would try putting a piece of wire in the idle air bleed and see if that helps, if it does then you need to shrink the air bleeds. It sounds like your problems are with the idle circuit and since it is not makeing the proper air fuel mix then when you open the throttle there is not enough signal to get the other circuits pulling fuel properly. But again before I changed the carb any more I would check the ign system and throw in some new plugs.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825966
10/10/10 01:01 PM
10/10/10 01:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
That is some large jets, i was told by demonsizzler that my setup with the choke removed should be about .101 primary, i too was using the 1966 rods but went to another # to lean out low speed. 5 turns on the tree seems like a lot.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825967
10/10/10 01:03 PM
10/10/10 01:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
when did you change the jets? after you had it at the track when it was running good, with good AF readings?
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825968
10/10/10 01:09 PM
10/10/10 01:09 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Hay Guys - members of the ThermoSquad ....
DID YOU HEAR that TODAY is the BIRTHDATE of the one-and-only Plastic Fantastic ?
Someone PLEASE ...post a pic of a cake ....with some flaming Berri Crabs on-top !
Re: TQ tuning issue using M1 intake (SB stroker) [Re: ademon] #825969
10/10/10 04:50 PM
10/10/10 04:50 PM
Moparmal Offline OP
Moparmal  Offline OP
I changed the jets out after I went racing and when i swapped the intake.
I was running .101s with three turns on the tree, and .138 secondaries.
I'll try limiting the idle air bleeds and see if that makes any difference -
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825970
10/10/10 05:02 PM
10/10/10 05:02 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Mal, what base gasket are you using under the carb?
I ask this because the wrong base gasket can make the carb loose the idle circuit. Also if you have a lean condition caused by an intake manifold leak, the cylinder next to the cylinder with the intake intake leak will show that the plugs are different in color or inconsistent in color.
I have done a lot of testing with the MP single plane intake and T.Q. carbs and it is a very good match and works well. Your jet size on the primaries would normally be too big, David.
Re: TQ tuning issue using M1 intake (SB stroker) [Re: DEMONSIZZLER] #825971
10/11/10 05:46 AM
10/11/10 05:46 AM
Moparmal Offline OP
Moparmal  Offline OP
Hi all
Well I swapped in a borrowed 650 AVS and the car purred like a kitten
- no surging,
- no variation of vacuum (held steady at 14 and didn't sag after blipping the throttle)
- Even the idle mixture was perfect and no variation on the AF guage.
Seems its clearly the TQ and not an intake Vac leak.
So -
This means I have to get the TQ working.
Dave - thanks for chiming in - what sort of base gasket should I be using?
(I know the jets are too big - that was a desperate attempt by me to try to get the idle/low speed circuit driveable)
Any tricks to get the idle circuit flowing a little better?
I guess I could elongate the idle slots a little - anything else?
Re: TQ tuning issue using M1 intake (SB stroker) [Re: Moparmal] #825972
10/11/10 11:04 AM
10/11/10 11:04 AM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
Take a look at this old post of mine...similar issue maybe? I have tried a number of things so far, some with greater success, others going the wrong way LOL.
https://board.moparts.org/ubbthreads/show...rt=all&vc=1
