Is it possible to machine HP manifold gasket surface? #825582
10/09/10 03:07 PM
10/09/10 03:07 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I've had a litttle tic tic tic leak forever on my RR . I replaced the exhaust flanges, half the exhaust and numerous gaskets with no luck. I was thinking they might be leaking at the manifold gasket surface. It has the stock waffled tin gaskets. I also need to reseal the manifold stud treads since they leak a little. Whats a good sealer to use on the studs. My plan was to remove the manifolds, sandblast, Por 15 manifold grey paint, have them resurfaced, new Mr Gasket hi temp gaskets and reseal the stud threads. Am I missing anything.? Thanks
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825583
10/09/10 03:24 PM
10/09/10 03:24 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
i have always used hi-temp black permatex on the stud threads,never had a problem. as for the manifolds,i just use a good straight edge and a 90 degree air grinder with a 36 grit sanding pad. then i install them with good fel-pro exhaust manifold gaskets. have never had any leaks or issues with them.
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825584
10/09/10 03:25 PM
10/09/10 03:25 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Cr8crshr bought a used set for his Satellite project and had them surfaced to CYA and when he went to torque them it broke one of the eyelets. He used Remflex gaskets. Soooooooo he got the repops from Yr. 1 and comparing the 2 surfaces, he found the old ones where alot thinner, so maybe the old ones had been surfaced a time or two. Just something to think about that they might not be able to handle it. Good luck though with whatever you decide.
Re: Is it possible to machine HP manifold gasket surface? [Re: stubbs300 ] #825585
10/09/10 03:36 PM
10/09/10 03:36 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
I'm guessing the the eye hole broke because the manifold wasn't actually flat to begin with. These manifolds are difficult to set up on a mill or grinder, but it can be done.
Re: Is it possible to machine HP manifold gasket surface? [Re: drew72] #825586
10/09/10 03:52 PM
10/09/10 03:52 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Try some hi-temp rtv silicone on both sides of the gasket and see if that cures it. A little crude but it is the easiest solution if it is leaking at the gasket flange and not too badly warped.
Kevin
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825587
10/09/10 04:24 PM
10/09/10 04:24 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Sure, they warp all the time, any machine shop can clean 'em up (mill or surface grind).
OEM there were no gaskets and none were needed. Warped, though, thick gaskets are helpful, but if they blow out, you have an even bigger leak.
Rick
Re: Is it possible to machine HP manifold gasket surface? [Re: Rick_Ehrenberg] #825588
10/09/10 06:07 PM
10/09/10 06:07 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Copper high temp rtv (no gasket needed) will seal stock cast iron exhaust manifolds.
Re: Is it possible to machine HP manifold gasket surface? [Re: Neil] #825589
10/09/10 06:14 PM
10/09/10 06:14 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
i have heard that the most leak-free combo is some soft copper gaskets that seal-well and also allow the exh-man heat to weap-off into the cyl head.
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825590
10/09/10 11:12 PM
10/09/10 11:12 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I have every used one I get resurfaced because they are not flat after 30 plus years , any good machine shop can do it .
Re: Is it possible to machine HP manifold gasket surface? [Re: JohnRR] #825591
10/10/10 01:26 AM
10/10/10 01:26 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The trick is how to find a "GOOD" machine shop.
Kevin
Re: Is it possible to machine HP manifold gasket surface? [Re: Twostick] #825592
10/10/10 02:43 AM
10/10/10 02:43 AM
Woodbridge,CA
Woodbridge,CA
I have a great machine shop. Looks like I had a small leak. I can't believe I drove this this 12K miles like this! FYI machine your manifolds during rebuild!
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825593
10/10/10 02:52 AM
10/10/10 02:52 AM
Woodbridge,CA
Woodbridge,CA
The centers are in by 1/32-1/16th! Sand blast, magnaflux, machine, POR 15 manifold gray. Lots of leaks on the studs. That was caused by using never seize instead of thread sealer, Duh! My Bad! Anybody know where I can get a reasonably priced heat flapper thingamajigg (heat riser?) May as well fix that too.
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825594
10/10/10 10:20 AM
10/10/10 10:20 AM
What type of choke set up are you using on your carb ?
Re: Is it possible to machine HP manifold gasket surface? [Re: stubbs300 ] #825595
10/10/10 12:17 PM
10/10/10 12:17 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Yep they broke due to stress cracks from years of use. Hot then Cold will do that to cast materials. Even if they appear to be in good shape, the interior metallurgy can have flaws that will be brought out after lengthy use. Any way...with the new Y1 manifolds and using the Remflex Gaskets, I feel I have a good seal. EBoogher is right that from the factory they didn't use any gaskets. I did this time just because and after my initial break in run on the new motor I will re-torque the manifold bolts. NAS Backyard...today I will be out in my shop organizing stuff and I have a complete Heat Riser Kit..if I can find it , you can have it. I will PM with details later....cr8crshr/Bill
Re: Is it possible to machine HP manifold gasket surface? [Re: CR8CRSHR] #825596
10/10/10 02:30 PM
10/10/10 02:30 PM
Woodbridge,CA
Woodbridge,CA
Manual choke. Thanks Bill! I'm running an 800cfm Edelbrock but will be trying a little "experiment" with a cough!spit! choke! gm qjet.
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825597
10/10/10 06:00 PM
10/10/10 06:00 PM
Woodbridge,CA
Woodbridge,CA
Sandblasted...
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825598
10/10/10 06:04 PM
10/10/10 06:04 PM
Woodbridge,CA
Woodbridge,CA
POR 15 Manifold Gray, ready for machine shop, I'll put another coat on when there done.
Re: Is it possible to machine HP manifold gasket surface? [Re: NAS Backyard] #825599
10/10/10 06:11 PM
10/10/10 06:11 PM
With a manual choke you don't need the flapper , I'd just remove it completely and block the holes .
Re: Is it possible to machine HP manifold gasket surface? [Re: JohnRR] #825600
10/11/10 11:08 AM
10/11/10 11:08 AM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
That is correct also. If you are still interested though I do have one. Still looking for it as I spend today in the shop....
Re: Is it possible to machine HP manifold gasket surface? [Re: CR8CRSHR] #825601
10/11/10 02:32 PM
10/11/10 02:32 PM
Woodbridge,CA
Woodbridge,CA
Thanks for the offer Bill, I'm going to leave the holes plugged up for now. Who knows , there may be a set of TTI's in the future!
