Cam phasing vs. intake reversion #825534
10/09/10 01:10 PM
10/09/10 01:10 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
If you wanted to reduce the likelihood of intake reversion w/ a particular camshaft, would you want to advance it to close the exhaust sooner OR retard it to delay the point where the intake opens?
Re: Cam phasing vs. intake reversion [Re: BradH] #825535
10/09/10 01:14 PM
10/09/10 01:14 PM
organ
maximum entropy Offline
organ
i would get the appropriate cam. if you advance the cam, you'll have pulse reversion, and if you retard it, you'd get pulse and exhaust. i think. or is it the other way around?
Re: Cam phasing vs. intake reversion [Re: BradH] #825536
10/09/10 02:34 PM
10/09/10 02:34 PM
SoCal
Brian Hafliger Offline
SoCal
reducing overlap is usually going to help so advancing or retarding will only show you "trends".
Closing the exhaust sooner is more likely to help reversion problems but without changing overlap it's not going to make much of a difference.
This is for WOT tuning only.
Brian Hafliger
Re: Cam phasing vs. intake reversion [Re: Brian Hafliger] #825537
10/09/10 03:20 PM
10/09/10 03:20 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Good to see a post from you Brian. I haven't noticed you posting much lately. I always like to hear your opinions.
Mark
Re: Cam phasing vs. intake reversion [Re: BradH] #825538
10/09/10 03:32 PM
10/09/10 03:32 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
you could try a anti reversion plate.
Re: Cam phasing vs. intake reversion [Re: mac56] #825539
10/09/10 03:39 PM
10/09/10 03:39 PM
SoCal
SoCal
Mark
Nice to be posting again...been soooo busy!!
Thank you!!!!!
Brian Hafliger
Re: Cam phasing vs. intake reversion [Re: BradH] #825540
10/09/10 04:13 PM
10/09/10 04:13 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
where is the occurring and why assuming a likelihood ?
home of the
Sox and Martin Hemi Duster
Re: Cam phasing vs. intake reversion [Re: HEMIFRED] #825541
10/09/10 04:47 PM
10/09/10 04:47 PM
BradH Offline OP
BradH  Offline OP
When Dwayne P. freshened up the heads, he mentioned seeing more indications of reversion in the intake ports than expected. The cam's worked well on the dyno and the track, but might have a bit more overlap than "ideal" for a full exhaust system and street-driven car. No plans at this point to change the cam (again), so I was curious if the phasing might have any impact on it.
Re: Cam phasing vs. intake reversion [Re: BradH] #825542
10/09/10 04:57 PM
10/09/10 04:57 PM
SoCal
SoCal
What are the engine/cam/exhaust specs?
Brian Hafliger
Re: Cam phasing vs. intake reversion [Re: BradH] #825543
10/09/10 05:34 PM
10/09/10 05:34 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Did the reversion occur at cruising speeds or wide open throttle or both? Without knowing that, it would be hard to know if it was hurting your performance.
Getting old just means you were smarter than some and luckier than others.
Re: Cam phasing vs. intake reversion [Re: dannysbee] #825544
10/09/10 06:20 PM
10/09/10 06:20 PM
BradH Offline OP
BradH  Offline OP
How would somebody be able to tell under what conditions it was happening?
Re: Cam phasing vs. intake reversion [Re: Brian Hafliger] #825545
10/09/10 06:24 PM
10/09/10 06:24 PM
BradH Offline OP
BradH  Offline OP
RB 452 w/ ported Stage VI heads, 10.8 CR, Comp XX 266 @ .050", .600", 1.5 rockers, 108 LSA (104 ICL measured at .050"), Victor 4150 intake w/ BG 4150 carb w/ 1.42" venturi x 1.75" throttle, 2" TTI headers & 3" x-pipe exhaust system.
Re: Cam phasing vs. intake reversion [Re: BradH] #825546
10/09/10 07:24 PM
10/09/10 07:24 PM
UK
602heavy Offline
602heavy  Offline
UK
I think seat to seat duration has a direct effect regard reversion , closing intake valve too late can cause a positive pressure differential between cylinder & back of intake valve.....had reversion problems with a 440 , advanced ICL from 108* to 104* & reversion cleaned up , i believe the earlier closing int valve helped regards reversion..........same applied with the 605" , tightened intake lash .006" tighter from cam card & noticed soot around intake runners & underside of carb , loosened lash & reversion cleaned up.
Re: Cam phasing vs. intake reversion [Re: 602heavy] #825547
10/09/10 07:26 PM
10/09/10 07:26 PM
UK
602heavy Offline
602heavy  Offline
UK
posted twice
Re: Cam phasing vs. intake reversion [Re: BradH] #825548
10/09/10 08:11 PM
10/09/10 08:11 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Brad I was just making a point. But you could clean every thing up, take it out and cruise it a bit then pull the intake.
Re: Cam phasing vs. intake reversion [Re: BradH] #825549
10/09/10 09:25 PM
10/09/10 09:25 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I understand that reversion occurs big time upon deceleration and it might show to be misleading but has no effect on much else
home of the
Re: Cam phasing vs. intake reversion [Re: HEMIFRED] #825550
10/09/10 09:39 PM
10/09/10 09:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I think the reversion may be occuring at lower rpms and less than WOT. Kind of what I think Fred's talking about.
Re: Cam phasing vs. intake reversion [Re: moper] #825551
10/09/10 09:56 PM
10/09/10 09:56 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Re: Cam phasing vs. intake reversion [Re: BradH] #825552
10/09/10 10:20 PM
10/09/10 10:20 PM
SoCal
SoCal
If it was driven on the street even a short time you'll see exhaust in the intake tract.
Sometimes all the way up to the carb! No way to get rid of it carbed.
I will say that with full exhaust system, I will run as much as 12° split between intake and exhaust lobes.
Brian
Brian Hafliger
Re: Cam phasing vs. intake reversion [Re: HEMIFRED] #825553
10/09/10 10:25 PM
10/09/10 10:25 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
now here's a chart to follow use only the red path unless it's past 5pm and you are using 89 pmup.
otherwise the black and race gas
home of the
