Re: Comp cams ???
[Re: Benssatellite69]
#825511
10/09/10 12:59 PM
10/09/10 12:59 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I run a .588 Comp solid in my 440.Been if for 10 years street and strip.No problems.Rocky
Chrysler Firepower
Re: Comp cams ???
[Re: Mopar_Country]
#825514
10/09/10 01:21 PM
10/09/10 01:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I ran a Comp 525 hyd for years. Only issue I had was when I tried to skimp on lifters.
Get the better lifters and you should be just fine.
Re: Comp cams ???
[Re: therocks]
#825517
10/10/10 10:33 AM
10/10/10 10:33 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Rocky unfortunately what you purchased 10 Years ago has little bearing on today's WORLD economy and what is rolling out the door of comp these days.
I am doing a 440 for a friend and we used a comp XE268 , off the shelf grind which are NOT ground by comp , they are done by their core supplier and god only knows where. It lasted 7mins of break in in time before it started clacking loudly, shut it down and look over the cam and we can see one lobe that looks weird and you could tell by the bottom of the lifter that it was not rotating well, the lifter moves in the bore fine.
After a few calls I end up getting the cam I should have gotten which was a Comp custom thru Dwayne Porter/fast68plymouth, He specified extra taper, not sure if we got it, and had it NITRIDED which added 150 bucks to the price tag and an extra week to get the cam, bought a set of Crower camsaver lifters and a set of adjustable pushrods from Smith Bros. so we can set the preload exact.
Ran the engine on Friday and it appears to have lasted at least the 40mins of break in. I'm going to pull the intake to inspect everything and reset lifter preload. But man is this cam LOUD for a hyd. flat tappet, we suspect it's the less that optimal clearance in the lifters, but that's a whole 'nother subject for another thread.
Re: Comp cams ???
#825518
10/10/10 10:34 AM
10/10/10 10:34 AM
JohnRR
U.S.S.A.
O.k cool I am gonna hope everyone tells me that cuz I really want this cam. Thanks alot Rocky!
You want to hear from people that have bought Comp cams within the last year or two, not 10 yr old parts .
Re: Comp cams ???
[Re: JohnRR]
#825519
10/10/10 11:47 AM
10/10/10 11:47 AM
therocks
Niles , Ohio
I know mine is at least 10 years old but I had good luck with it and the Comp solids.Probally the best cams for $$$$ spent are the Summit ones Ive bought.Last one was 2 years ago for the kids SB in his truck.I have/had a BB Sumit cam that we pulled from my 440 and put in a 383.That cam lifter set is at least 30 years old and still running.Yeah I know 30 years ago there was some quality but the last few I bought are still going strong.My kid has a Hughes cam in the 413 but its at least 10 years old also.I also have some old solid cams in the garage that are probally 25 years old.Guess Ill save them for a rainy day.Rocky
Chrysler Firepower
Re: Comp cams ???
[Re: dustergirl340]
#825521
10/10/10 12:12 PM
10/10/10 12:12 PM
Posts: 565 IA
landon1
IA
i built my 440 last summer with a comp xe268 cam and lifter kit. used VR1 10-30 with comp break-in additive and comp assembly lube. so far, no problems. sure, i only have about 350 miles or so on the car, but it's been beat to hell in those 350 miles and it still runs just as well as when first together.
'71 Satellite Sebring 440
Re: Comp cams ???
#825523
10/11/10 08:31 AM
10/11/10 08:31 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Has anyone had any issues w/ comp cams? I was looking at a 519 lift. something w/ a little more pep and wanna keep the cam hydraulic flat tappet its a 440 and if the comp cam sucks can someone recommend a better cam w/ a higher lift/duration than a Mopar 509 cam,sorry 4 not posting much here I just dont wanna give people the wrong info.
Customer service is little questionable. The two times I called them it seems they were ready excerpts from their book of excuses.
I've dealt with Lunati and they seem more willing to sort things out.
Re: Comp cams ???
[Re: torkrules]
#825524
10/11/10 11:48 AM
10/11/10 11:48 AM
JohnRR
U.S.S.A.
I was told that a couple of the owners of Comp bought Lunati from Holley .
Re: Comp cams ???
[Re: JohnRR]
#825525
10/11/10 12:51 PM
10/11/10 12:51 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I've installed two last year. Got a 3rd sitting waiting for my truck's 360. All XE off the shelf grinds. No problems with them following proper procedures. John, you of all people know you can still do everything perfectly and still have a cam go south. Unless you have the bores bushed to correct any cam to lifter angle isues, you never know. I know I don't spend the cash for that on most builds. Comp's quality is comparable with most of the better cam companies. that's not to say they are all perfect, but I have yet to lose one.
Re: Comp cams ???
[Re: JohnRR]
#825527
10/11/10 03:42 PM
10/11/10 03:42 PM
torkrules
I'm neurotic
I'm neurotic
Maybe the better half bought them?
