Vent window pivot gaskets? #825323
10/08/10 10:47 PM
10/08/10 10:47 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
Can I buy just the rubber flat washer and 'hat' gasket/washer that is used on the vent window pivots? If so...where?
Re: Vent window pivot gaskets? [Re: GregCon] #825324
10/12/10 12:45 AM
10/12/10 12:45 AM
In.
bjg Offline
bjg  Offline
In.
Are you talking about the rubber that goes on the screw in vent window glass.
Re: Vent window pivot gaskets? [Re: bjg] #825325
10/12/10 01:13 AM
10/12/10 01:13 AM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
yes
Re: Vent window pivot gaskets? [Re: GregCon] #825326
10/12/10 02:17 PM
10/12/10 02:17 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
http://www.rtspecialties.net/proddetail.asp?prod=2583551 not sure if this is what you are talking about.
Re: Vent window pivot gaskets? [Re: LYNCHROAD69.5] #825327
10/14/10 01:48 PM
10/14/10 01:48 PM
Utah
E
Eagleone1983 Offline
E
Utah
Lynch, those aren't them. What you have is the pieces that fit in the quarter window regulator frame.
Re: Vent window pivot gaskets? [Re: LYNCHROAD69.5] #825328
10/14/10 02:07 PM
10/14/10 02:07 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
These black pieces are what I am referring to.
Re: Vent window pivot gaskets? [Re: GregCon] #825329
10/14/10 02:32 PM
10/14/10 02:32 PM
In.
bjg Offline
bjg  Offline
In.
I have a pair send me a message.
Re: Vent window pivot gaskets? [Re: bjg] #825330
10/14/10 02:43 PM
10/14/10 02:43 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I too could use a pair of these along with the screws. Anyone know who carries these? Thanks!
Re: Vent window pivot gaskets? [Re: superbeedave] #825331
10/14/10 03:06 PM
10/14/10 03:06 PM
In.
bjg Offline
bjg  Offline
In.
I don't know of anyone that reproduce these I bought NOS ones awhile ago.
