don't know about the face plate. 4spd drive shaft not the same lenght as auto. do you have a Z-bar with the bushings and springs and ball studs,(frame and bellhsg) throw out bearing fork and dust boot, tranny support. are you going to put in backup light and netural safety switch? and then misc nuts bolts. i put in a keisler 5spd and love it. have you look at that option? being the car was a auto remember that the pilotshaft hole in the auto crank is not as deep as the pilotshaft hole in a four spd crank, you will need the cut off about 1/2 to 3/4 inch of the inputshaft of the tranny.
